I can't think of anything that would make it any different than tossing in a newer one except the injectors.
Swap your alternator and alt bracket onto the L67. Get the wiring kit from ZZP or pull out the soldering iron and your map sensor will be all set. I think the injectors are different, so you'd need to change those connectors. Overall though..nothing an hour of work can't solve.
