Thread: 2004 gtp electrical issues
Results 1 to 3 of 3
  1. #1 2004 gtp electrical issues
    Jul 2012
    Minnesota
    I just bought a 2004 gtp comp g 2 days ago. I was driving today and all the elctronics shut down on me then restarted. I was just driving home from work tonight when the gas, coolant temp, and rpm gauges all stopped working and the comp flashed to service traction control system. I pulled over and shut off the car, restarted it, then all the gauges worked fine again. Now i have a check engine light on though.
    If anyone has some knowledge of this please help out.
    Thank you!
  2. #2 Re: 2004 gtp electrical issues
    Maybe a loose ground somewhere?
    Just a thought here on why the car just died, a known issue on the 3800 platform is the Crank Sensor failing and causing everything to shut down, but then allowing everything to restart and work perfect till it happens again.
    I would take the car to an o reillys and or autozone and get it scanned for free and report back with a check engine light code, with the code we can help you figure out what the problem may be.
  3. #3 Re: 2004 gtp electrical issues
    Jul 2012
    Minnesota
    Alright thank you!
    Ill take it over there tomorrow morning and report back to you!
  1. electrical issues
    By toastisdead in forum Audio, Security & Visual Electronics
    Last Post: 12-30-2012, 10:44 PM
  2. Electrical issues
    By Etatheta in forum General Grand Prix Discussion
    Last Post: 02-18-2012, 01:13 PM
  3. Electrical Issues
    By DStepien in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2012, 10:06 PM
  4. Car issues - electrical and key
    By JJ133169 in forum General Tech Discussion
    Last Post: 06-20-2011, 07:20 PM
  5. possible electrical issues
    By jcmonteman in forum General Tech Discussion
    Last Post: 04-18-2011, 05:47 PM
