Thread: weird electrical issues
Results 1 to 3 of 3
asite57 weird electrical issues 07-07-2012, 10:17 PM
Sven the Sexman Re: weird electrical issues 07-07-2012, 10:22 PM
asite57 Re: weird electrical issues 07-08-2012, 09:49 PM
  1. #1 weird electrical issues
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    so my 99 GTP with 174k on it started to have electrical issues well first of all the key sometimes gets stuck in the ignition and sometimes when i turn the key off or even turn the lights off the car will start dinging for about a 3 min straight and sometimes the BATTERY LOW COOLANT and LOW OIL PRESSURE lights will come on but the battery is secure, the coolant is not low and there is no air in the system, and the oil pressure is not low (i also replaced the sending unit) those light will stay on all the time when the car is off and soemtimes the seatbelt light will stay on to sometimes theyll flash i have no clue what the issue is or what could be causing this
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: weird electrical issues
    Mar 2012
    NC
    My first thought is ignition switch, but maybe someone with a bit more experience in this area will chime in.
  3. #3 Re: weird electrical issues
    Oct 2011
    Michigan
    bump
  1. So I got a weird little electrical thing goin on...
    By FriboRage in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2012, 12:25 AM
  2. Weird Electrical Stuff Tonight
    By FriboRage in forum General Tech Discussion
    Last Post: 04-04-2011, 03:08 PM
  3. Weird Electrical Issues
    By tdm571 in forum General Tech Discussion
    Last Post: 03-15-2011, 09:34 AM
  4. Weird Electrical Issues
    By Dabman in forum General Tech Discussion
    Last Post: 03-02-2011, 05:35 PM
  5. Weird electrical/transmission/stall issues
    By Perry125 in forum General Tech Discussion
    Last Post: 09-19-2010, 10:16 AM
