Thread: PLEASE HELP! Codes P0102 & P0452
Results 1 to 6 of 6
  1. #1 Re: PLEASE HELP! Codes P0102 & P0452
    Saraland Alabama
    low input sounds like a voltage issue, do you have another pcm to swap out with and see if it stays gone with that?
  2. #2 Re: PLEASE HELP! Codes P0102 & P0452
    SE Level Member TAWinner23's Avatar
    Locust Grove, GA
    I checked the fuses in the engine bay and in the car that where listed for emissions and/or maf...not sure if one of them was #25. I will do that tomorrow.
    Also, I do not have another pcm to try out.
    The first PCM that I got around the first of the year had issues. The EGR insufficient flow code would come on and off all the time. I sent it back for another...and after about a month of normal driving...gremlins are back. The car starts up and idles all jacked up for a couple of minutes (sounds like it wants to stall, like a 70's Camaro) and then runs fine. But the exhaust is real rich (similar problem with first pcm). When I'm driving and I let off the gas the rpms jump up and down.
    Thanks for the help...any other suggestions would be great...This has been a nightmare since the first of the year...and there is another issue that I am going to post about a possible axle issue
  1. 3 codes, what could it be?
    By spidamanSS in forum General Tech Discussion
    Last Post: 08-19-2008, 02:24 AM
  2. I got some codes
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2008, 07:41 AM
  3. code p0102
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2008, 12:09 PM
  4. Runs bad, won't start...Codes P0401 & P0452
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-03-2008, 06:55 PM
  5. ecu codes ??
    By sal3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2008, 12:48 PM
