Thread: What type of octane should I use on a GTP
Results 1 to 20 of 25
Stinger357 What type of octane should I... 03-09-2012, 07:34 PM
Fivefingerdeathpunch Re: What type of octane... 03-09-2012, 07:37 PM
txslow6 Re: What type of octane... 03-09-2012, 08:07 PM
Tuner-Extraordinaire Re: What type of octane... 05-03-2012, 11:22 PM
DanPrixGTP Re: What type of octane... 05-04-2012, 07:14 AM
txslow6 Re: What type of octane... 05-04-2012, 07:18 AM
gmpowered Re: What type of octane... 05-04-2012, 10:19 AM
blueguy Re: What type of octane... 05-04-2012, 10:20 AM
strtarrow Re: What type of octane... 06-28-2012, 10:53 AM
Tuner-Extraordinaire Re: What type of octane... 06-28-2012, 10:54 AM
Fivefingerdeathpunch Re: What type of octane... 06-28-2012, 11:22 AM
Tuner-Extraordinaire Re: What type of octane... 06-29-2012, 10:29 PM
Fivefingerdeathpunch Re: What type of octane... 06-29-2012, 10:38 PM
rynoman03 Re: What type of octane... 06-29-2012, 10:31 PM
Slick2500 Re: What type of octane... 06-29-2012, 10:33 PM
Tuner-Extraordinaire Re: What type of octane... 06-29-2012, 10:40 PM
Fivefingerdeathpunch Re: What type of octane... 06-29-2012, 10:47 PM
Tuner-Extraordinaire Re: What type of octane... 06-29-2012, 10:49 PM
codyAK Re: What type of octane... 06-30-2012, 12:15 AM
matt5112 Lookup canadia prices. ... 06-30-2012, 11:51 AM
dsmuts Re: What type of octane... 06-30-2012, 11:57 AM
Fivefingerdeathpunch Re: What type of octane... 06-30-2012, 11:58 AM
Oxfire Re: What type of octane... 06-30-2012, 04:41 PM
indygrandprix Re: What type of octane... 06-30-2012, 05:02 PM
Tuner-Extraordinaire Re: What type of octane... 06-30-2012, 11:35 PM
  1. #1 What type of octane should I use on a GTP
    SE Level Member Stinger357's Avatar
    Plano, Texas
    I have been using 87 octance will that bog the car down or should I have mid grade or high end octane? Any ideas?
  2. #2 Re: What type of octane should I use on a GTP
    GTP's need to run on 91+ octane, because the supercharger and low compression motors.
    So just fill with 91 or higher and call it a day.
  3. #3 Re: What type of octane should I use on a GTP
    Texas
    87 will cause it to detonate if going into boost.
    I've run 87 before, but that's when I drove without my S/C belt.
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: What type of octane should I use on a GTP
    Out West
    I'd suggest premium fuel absolutely..
    The car will go into the low timing table if it detects enough KR -- Not the most optimal way to go about it but it DOES work..
    These cars knock even on 93 bone stock. PM me about a tune if you insist on running regular though once you get your ride back on the road.
    Whine with your Cheese?
  5. #5 Re: What type of octane should I use on a GTP
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    91 octane all day. Spend the extra $5ish per fill up for premium fuel if you wanna make your car last
  6. #6 Re: What type of octane should I use on a GTP
    Texas
    Awesome for bumping 2 month old thread.
    85 Corvette
    01 TA
    03 Z06
  7. #7 Re: What type of octane should I use on a GTP
    Saratoga NY
    Quote Originally Posted by txslow6 View Post
    LOL
    I ran 87 on a 3.1 pulley l26 bottom with no KR. AFR in the 10s at wot just like a canned tune.
    I would suggest 87 for someone who just drives their Stock car. BUT if you want to drive it hard or think its a race car you should use 92.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  8. #8 Re: What type of octane should I use on a GTP
    Quote Originally Posted by gmpowered View Post
    LOL
    Yeah, sounds like a great idea.
  9. #9 Re: What type of octane should I use on a GTP
    Jun 2012
    Mount Airy, NC
    My Harley manual calls for high octane (91 or better) as does my GTP manual. A lot more painful in the GP though with a 17 gallon tank.
  10. #10 Re: What type of octane should I use on a GTP
    Out West
    85 octane.
    At 14,000ft altitude.
  11. #11 Re: What type of octane should I use on a GTP
    3 extra bucks per fuel up, cant ever hurt the bank.
  12. #12 Re: What type of octane should I use on a GTP
    Out West
    $4-7
  13. #13 Re: What type of octane should I use on a GTP
    Quote Originally Posted by Nixon View Post
    $4-7
    3-5,
    unless you buy 91+ thats almost .50 more per gallon.
  14. #14 Re: What type of octane should I use on a GTP
    Topeka, KS
    91octane or higher. ALWAYS!
  15. #15 Re: What type of octane should I use on a GTP
    Racegas foo
  16. #16 Re: What type of octane should I use on a GTP
    Out West
    $.30-50c/gal more on a 15gal fillup is $4.50-$7.50
  17. #17 Re: What type of octane should I use on a GTP
    Wanna know something?
    Texas is gay.
    Everywhere else its .20 to .30 more for 91+, you'd out of your mind to buy gas thats .50 more 91+. and running your tank that low is going to kill the fuel pump faster.
  18. #18 Re: What type of octane should I use on a GTP
    Out West
    Lol i usually filled up @ 13-14gal mark. -- the point is still the same.
    My $.30c for 93oct > Your $.20c for 91oct
  19. #19 Re: What type of octane should I use on a GTP
    Ocala, FL
    I used to always see a price for regular, +.$10 for midgrade, +.$10 for premium. Now it's always marked way higher.
    Sam's club around here often has 93 for .30 more opposed to other stations being more, so I normally buy gas there.
    Texas is gay.
    10-20 cents per litre for 39-78 cents per gallon for 7-13 dollars per tank.
  1. What octane is best for 3.4" set up ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 08-01-2010, 07:14 AM
  2. 93 octane in a N/A?
    By JESSEGOTTA GP GT in forum General Tech Discussion
    Last Post: 03-21-2010, 07:10 PM
  3. What Octane gas to use?!!!
    By Redbirds2230 in forum General Tech Discussion
    Last Post: 10-27-2009, 03:55 AM
  4. Octane
    By Davisgtp in forum Off Topic Discussion
    Last Post: 03-18-2009, 10:20 AM
  5. 98 GT Gas Octane?
    By Shingen in forum General Tech Discussion
    Last Post: 01-30-2009, 05:49 AM
