Thread: Whiter & Brighter Lamps
Results 1 to 13 of 13
  1. #1 Whiter & Brighter Lamps
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    I currently have SilverStar Ultra9007 headlights and SilverStar880 fog lights. Im looking for something a little "whiter and brighter" and as for headlights, i was gonna shoot for the SilverStar zXe. Any thoughts about them? Also, what about my fog lamps? Whats pretty good out there for those?
    Im not looking to upgrade assemblies due to tight budget, but i am looking for something a bit better for both headlights and fog lights with the "whiter and brighter" light.
    Links would be great
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  2. #2 Re: Whiter & Brighter Lamps
    St. Louis
    You can put 5K HID's in the stock fog housings. I bought a kit from a member here and they work just fine. Came with ballast and wiring harness too. Brighter than hell, lol... Although I need to look into upgrading the headlights to match. It's bright enough that I could drive with just the fogs on if need be.
    Eh, hids mean no high beams and more scattered light than usable.
    Unless you never drive unlit roads you'll miss your highs greatly.
    Ive recently been told zxe's work very well.
    Might be worth a shot.
  4. #4 Re: Whiter & Brighter Lamps
    Jan 2012
    Sturgis, MI
    You think they are brighter then SilverStar Ultras or equal? And know anything good about fog lamps?
    Miles: 170-XXX
    Engine: 3.8L V6
  5. #5 Re: Whiter & Brighter Lamps
    St. Louis
    Yeah, forgot about that. I guess projectors would be the way to go for that. I have to read up on what's out there. I drive completely unlit roads all the time out where I live (2 lane country highway populated with deer) so HID lows def. won't work. I still need to rewire my fogs to stay on with the highs. With lows and the HID fogs it acutally seems brighter than using just the highs, and I have 100% clear headlight capsules. Could just be me though.
    Was told zxe are brighter that ultras and nighthawk platinums.
    Fogs bounce light around down low.
    Theyre for driving in fog.
  7. #7 Re: Whiter & Brighter Lamps
    Dec 2008
    Lawndale, CA
    Just remember that any bulb that has a blue coating has less light output than a clear bulb. I have the philips xtreme power and those have been the best bulbs I have used. I am also running a relay harness to use them at there full potential. There are really no good bulbs in the 880 size. I would recommend an aftermarket set of glass fogs that utilize an H3 bulb.
  8. #8 Re: Whiter & Brighter Lamps
    Jan 2012
    Sturgis, MI
    They can be pretty good for snow storms also. I didnt have any of my SilverStars (fog and head lamps) nor did i have my new assemblies last winter so it made driving in a snow storm almost impossible on a highway until a car with bright headlights would pass me, lighting up the whole road almost, which forced me to get new assemblies and to try the SilverStars
    That was the end of winter when i got all this.
    Miles: 170-XXX
    Engine: 3.8L V6
  9. #9 Re: Whiter & Brighter Lamps
    Grand Island, Nebraska
    I have 8K HIDs and i dont miss my highs since the light is scattered enough. I think there are some that have HID highs and lows, but if there are they are more pricey. You could try upgrading wiring. Headlight harness, alt rewire, alt voltage booster, ect.
    The Boss Iceman6669's Avatar
    Jun 2011
    I have 5k HIDs and I have never used the highs. I even live out in BFE and still don't need the highs anymore.
    2011 F-150 Yote powered
  11. #11 Re: Whiter & Brighter Lamps
    GT Level Member thegipper's Avatar
    grafton, wi
    Quote Originally Posted by Iceman6669 View Post
    What he said ^
    5k HIDs ftw... No regular bulb will even come close. No need for brights, my VVME 5ks are insanely bright !
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  12. #12 Re: Whiter & Brighter Lamps
    Feb 2008
    I'd recommend projectors and HIDs. I had them and loved them when I had my grand prix. I now have a Monte with HIDs. The headlight capsules are so much better than the grand prixs that I never need my highs.
  13. #13 Re: Whiter & Brighter Lamps
    If your headlights are properly aimed, you'll need your high beams.
    Unless you never drive in the countryside.
  1. Need Help/Suggestions on Stop(Brake)Lamps/Interior Lamps/Cig. lighter.
    By Bulletproof Gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2011, 01:51 AM
  2. Need help with stop lamps, interior lamps!
    By Bulletproof Gtp in forum Audio, Security & Visual Electronics
    Last Post: 09-15-2011, 05:07 PM
  3. Brighter Tailights
    By gptrell502 in forum Visual/Body Modifications
    Last Post: 04-16-2010, 05:07 PM
  4. One HID fog brighter than the other
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 01-27-2010, 08:54 AM
  5. Brighter Fog lights?
    By matt5112 in forum Visual/Body Modifications
    Last Post: 08-31-2009, 04:15 PM
