Thread: No fuel pressure
Results 1 to 14 of 14
  1. #1 No fuel pressure
    Minnesota
    I installed and fixed some of the stuff on my 2002 Monte Carlo the other day. Fixed the intercooler added a catch can ect ect.
    The problem is that that car won't start and the fuel pump sounds like it is straining to prime. The only things I did to the fuel system were PRJ rails, magnafuel AFPR and stainless lines from in the engine bay to the AFPR and rail.
    The gauge that I installed on the FPR reads zero all the time. Even after priming the fuel pump a few times and cranking it over.
    I was thinking bad fuel pump, clogged filter or something clogging the line but I don't see how it could just go bad from just installing that new stuff.
  2. #2 Re: No fuel pressure
    Grand Island, Nebraska
    Did the gauge read at all before? you could take the access cover off and see if you can hear it better. fuel filters are also cheap.
  3. #3 Re: No fuel pressure
    Minnesota
    The gauge is new and mounted to the AFPR. I can hear the pump and hear it prime but sounds garbled. I have a fuel filter and a re-wire and Racetronix pump.
    The other reason I have not thrown that stuff on is because I wanted to start it before I added the pump and re-wire.
  4. #4 Re: No fuel pressure
    Apr 2009
    Fort Worth TX
    2002 has the return system, right? Are you sure you got the lines right?
  5. #5 Re: No fuel pressure
    Minnesota
    Quote Originally Posted by Rico View Post
    Yeah I went out and checked that and they are the correct lines.
  6. #6 Re: No fuel pressure
    sure the new pump is installed in the canister correctly?
  7. #7 Re: No fuel pressure
    Apr 2009
    Fort Worth TX
    Remove the incoming fitting on the filter and turn the key on. Catch the fuel in a cup or something. It probably just needs primed.
  8. #8 Re: No fuel pressure
    Minnesota
    I have not installed the new pump yet. It's still the stock pump and normal wiring.
    I will try that. I have to install a new filter anyways.
    Is it possible to not have enough fuel in the tank to prime the pump? I think I am at or below a 1/4 tank.
  9. #9 Re: No fuel pressure
    Apr 2009
    Fort Worth TX
    Do you trust your gauge?
  10. #10 Re: No fuel pressure
    Minnesota
    From what Paul said on the other forum I have the two lines switched. I need to change them and it should work out.
    On a side note.....I am going to remove the brake booster so I have more room to get the lines back off. (It was a pain in the ass the first time)
    Anyone have a picture and/or tips for getting the line going to the brake peddle from the booster off? I read it's a clip but I am a visual person.
  11. #11 Re: No fuel pressure
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by Pure2sin View Post
    You assured me the lines were on correct. Did you connect the pressure line to the return port?
    That would explain it.
  12. #12 Re: No fuel pressure
    He did... lol
    I have the clip in my car and should be able to get you a picture later today. If you look up from the brake pedal and find the rod coming to it, you'll see the clip. A flat screwdriver touching it, would have it off in a second.
  13. #13 Re: No fuel pressure
    Minnesota
    He did... lol
    Thanks Bill and everyone.
    For some reason when I did the lines I got it in my head that the sending line goes to the FPR first. lol
  14. #14 Re: No fuel pressure
    Apr 2009
    Fort Worth TX
    Bill won't let you live it down.
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. Low fuel pressure causes?
    By Selene2001 in forum General Tech Discussion
    Last Post: 03-20-2012, 03:50 PM
  3. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  4. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
