DTC P2135
CIRCUIT DESCRIPTION
The throttle position (TP) sensors 1 and 2 are located within the throttle body assembly. The TP sensors share a common 5-volt reference circuit and a common low reference circuit. The 5-volt reference circuit is also shared with the accelerator pedal position (APP) sensor 2. The 5-volt reference voltage is supplied on 2 separate engine control module (ECM) terminals, but the terminals are connected internally to the same voltage supply. Each TP sensor has an individual signal circuit, which provides the ECM with a signal voltage proportional to throttle the plate movement. When the throttle plate is in the closed position, the TP sensor 1 signal voltage is near the low reference and increases as the throttle plate is opened. The TP sensor 2 signal voltage at closed throttle is near the 5-volt reference and decreases as the throttle plate is opened. If the ECM detects that the TP sensors are not within a predicted value from each other, DTC P2135 sets.
DTC DESCRIPTOR
This diagnostic procedure supports the following DTC:
DTC P2135 Throttle Position (TP) Sensor 1-2 Correlation
CONDITIONS FOR RUNNING THE DTC
- DTCs P0122, P0123, P0222, P0223, P0601, P0602, P0603, P0604, P0606, P0607, P0641, P0651 are not set.
- The ignition is ON.
- DTC P2135 runs continuously when the above condition is met.
CONDITIONS FOR SETTING THE DTC
The ECM detects that the difference between TP sensor 1 and TP sensor 2 is more than the predicted value for less than 1 second .
ACTION TAKEN WHEN THE DTC SETS
- The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
- The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame and/or the Failure Records.
- The control module commands the TAC system to operate in the Reduced Engine Power mode.
- A message center or an indicator displays Reduced Engine Power.
- Under certain conditions the control module commands the engine OFF.
CONDITIONS FOR CLEARING THE MIL/DTC
- The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
- A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
- A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
- Clear the MIL and the DTC with a scan tool.
