Thread: Fuel Pressure Regulator New to Thread
Results 1 to 8 of 8
  1. #1 Fuel Pressure Regulator New to Thread
    Jun 2012
    MN
    Info needed:
    Attempting to remove FPR for the first time. Before I do this I keep reading/seeing (relieve fuel pressure). How do you do this????? Is this needed before remove the Vacuum line attached to the top of the FPR or even when I attempt to remove the actual FPR? Not sure what will happen.... I am checking to see if GAs is present in the FPR which I have been told may be causing my sons 2001 Buick Regal to stall under 5 MPH or not start most mornings evenings etc.... Thoughts?
  2. #2 Re: Fuel Pressure Regulator New to Thread
    Where at in MN?
  3. #3 Re: Fuel Pressure Regulator New to Thread
    Jun 2012
    MN
    St. Paul
  4. #4 Re: Fuel Pressure Regulator New to Thread
    Saratoga NY
    The FPR probably wont cause the stalling, you can relive the pressure at the schrader valve.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  5. #5 Re: Fuel Pressure Regulator New to Thread
    Jun 2012
    MN
    xcI'll have to find out where the schrader valve is... I'm not a car guy. So the gas (if any) in the FPR wouldn't cause these issues? Your thoughts on what it could be?
  6. #6 Re: Fuel Pressure Regulator New to Thread
    Saratoga NY
    If you follow the fuel lines, its that valve stem looking thingy, you can depress the needle if the car is cold, fuel should squirt.
    Scan for codes.
    If its cold its not in closed loop yet, could be something as simple as a dirty MAF
  7. #7 Re: Fuel Pressure Regulator New to Thread
    Jun 2012
    MN
    NO codes are coming up on Readers, and actually no CEL lights or anyting to speak of on the dash.... Cleaned Throttle Body and MAF already. getting worse on stalling and starting each day now.
  8. #8 Re: Fuel Pressure Regulator New to Thread
    moved thread.
    Intro section isn't for tech questions.
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. Fuel Pressure Regulator
    By RotyP in forum 04+ Specifics
    Last Post: 10-22-2011, 12:41 PM
  3. which fuel pressure regulator to buy?
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 05:09 PM
  4. Fuel Pressure regulator
    By xxch4osxx in forum General Tech Discussion
    Last Post: 09-08-2009, 06:26 AM
