Thread: 2000 GT oil leak
Results 1 to 14 of 14
  1. #1 2000 GT oil leak
    Oct 2011
    Vineland
    I have a 3.8 grand prix n/a, and i am losing approximately a qt of oil every 1500 or so miles due to a leak. I see a lot around the general oil pan area, above it as well.
    Also, I noticed little smoke coming from the front exhaust manifold.
    Could this be leaking from multiple locations? I want to get some tips before I get underneath and start throwing parts at it.
  2. #2 Re: 2000 GT oil leak
    good chance its all leaking from the front and rear valve cover gaskets.
    first thing first though, go get 2 cans of engine degreaser, and clean your engine, top to bottom. like car ramps/jack stands spray under it, and the trans.
    if your stock with your air box still, you can literally hose down everything under the hood, just avoid directly spraying the alternator.
    after the engine is nice and clean and dry, change your valve cover gaskets. if you have a air compressor blowing off the top 1/2 of the engine will get you working faster. back pack blower, what ever you got.
  3. #3 Re: 2000 GT oil leak
    St. Louis
    Don't forget to change the valve cover bolt grommets when you do the gaskets or you run the risk of leaking again.
    Oct 2011
    Vineland
    It doesnt seem difficult, but what about the oil pan gasket, if it is that?
    Also, isnt there a recall for those gaskets?
  5. #5 Re: 2000 GT oil leak
    nope, just the s.c cars from valve cover gasket. you would not be covered.
    the oil pan is leaking oil because the covers are leaking all over everything. (smoke off the front exhaust can only be the valve cover, oil leaks down) after you do the valve covers you will know if your pan is leaking or not.
    one step at a time grass hopper.
    Oct 2011
    Vineland
    I planned on at least hitting the back one. I even smell a bit of oil fumes through the vents when the air is on.
  7. #7 Re: 2000 GT oil leak
    do both.
  8. #8 Re: 2000 GT oil leak
    St. Louis
    Heck, the back one is the hardest one to do, lol... If you do that one then the front is a no-brainer.
  9. #9 Re: 2000 GT oil leak
    Oct 2011
    Vineland
    Well, I did both, and there is STILL a leak. Intake Manifold gasket possibly...?
  10. #10 Re: 2000 GT oil leak
    you need to clean it up and get under the car and look for a oil trail.
  11. #11 Re: 2000 GT oil leak
    Oct 2011
    Vineland
    I did. There's still a light oil burning smell, and some around the intake manifold area. I lost a qt of oil in just over a month, and I maybe drove 500 miles.
  12. #12 Re: 2000 GT oil leak
    Nov 2011
    NY
    Clean the engine and then get in there up close and take a look around, then you'll know where it is coming from.
    Did my lim a year ago, had to redo it as it and the valve covers were leaking again
    Its an easy fix tho...
  13. #13 Re: 2000 GT oil leak
    what v/c gaskets did you use?
    i did mine and they started to leak again real fast, back one too. figures rights? so i took it back off, cleaned it and the head up real good, smeared the thinnest smear of rtv on the gasket only, set it back nice, and snugged the bolts evenly as i could.
    not torqued, just snugged up good. been dry since.
    you see anything hitting the ground when parked?
  14. #14 Re: 2000 GT oil leak
    Oct 2011
    Vineland
    I forgot which brand. I did it back in like August.
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
