Thread: Obnoxious Squeal HELP!!! [Video Uploaded] ***SOLVED***
Results 1 to 20 of 30
  1. #1 Obnoxious Squeal HELP!!! [Video Uploaded] ***SOLVED***
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    Of course this squeal is "A LOT" louder then what my camera picked up but i need a solution because all im doing is covering the problem up by spraying a little bit of wd40 or silicone spray. It comes back within minutes. Im tired of covering this problem up, its solving nothing at all. The belt is in good condition also. Links to buy each pulley would be awesome guys 3.8L 3800 series II engine. Belt diagram below video just because. HELPPP!!!!!:th_sick1 :
    1st video
    Obnoxious Squeal - YouTube
    My apologies about the video being upside down. I have no idea how it was filmed that way....
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  2. #2 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    Have you tried a new belt? Pull the belt off and spin each pulley by hand and see if any make noises
  3. #3 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    Jan 2012
    Sturgis, MI
    When i replaced my tension pulley, i did just that and got no squeal. Now how would a belt make that kind of noise so damn loud?
    Miles: 170-XXX
    Engine: 3.8L V6
  4. #4 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    Jan 2012
    Philadelphia
    make sure all of your pulleys are on all the way, and make sure your belt is on all the way at the crank pulley
  5. #5 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    Jan 2012
    Sturgis, MI
    Yeah all pullies are fine.
    Miles: 170-XXX
    Engine: 3.8L V6
  6. #6 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    Yeah it sounds like your belt is slipping. Pull it off and wash it with dish soap to get all the crap out of the grooves let it dry then put it back on.
  7. #7 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    just for sh1ts and giggles did you start the car with the belts off? to see if the noise is gone or not?
  8. #8 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    Jan 2012
    Sturgis, MI
    I did just that but i got no where as usual...Tones of gunk got cleaned out though
    Yes i did that, nothing. I also spun the pullies with the belt off and nothing made any noise. I did spun the alternator pulley and it had a tiny little squeak to it but i know for a fact its not that....
    Threw a 2nd video up...asking about tensioner assembly
    Miles: 170-XXX
    Engine: 3.8L V6
  9. #9 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    i would when the cars off spray the idler, ( take the bolt off) and tensioner, if you have both, with some kind of oil, keep it off the belt, hold a paper towel around the belt, do one at a time.
    that is really sounding like a dry bearing or worn and running on a edge. if a shot of lube quiets it down you found it.
    the alt could also be the problem, not sure if you can see inside the case at all on yours but some times you can see the bearings in the case, give that a shot too.
    but only do one pulley at a time, the spray lube is a temp fix. and you want to know witch one you fixed/found bad.
  10. #10 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    Did you ever put a new belt on it?
  11. #11 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    its the tension pulley
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  12. #12 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    Jan 2012
    Sturgis, MI
    My last attempt was taking off the tensioner pulley and i used some lithium white grease to grease the little knob the tensioner pulley sits and spins on, that did nothing at all.
    I was thinking of checking into the alt just to be sure but as me being a new person to cars, id kinda maybe need a step by step to how remove everything, have a link maybe?
    No i didnt, didnt see why i would need to since mine is fine, i was told it didnt sound like a belt squeak. I do wanna note that even just a tiny bit of silicone spray on the belt, the squeal is gone but only gone for like a few minutes but then comes back.
    Quote Originally Posted by asite57 View Post
    The tensioner pulley on there is new so it cant be the pulley.
    Miles: 170-XXX
    Engine: 3.8L V6
  13. #13 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    the only thing left is the alt. harbor freight sell them mechanics stethoscopes for less than 10 bucks. to really trace it down before you dump 100 into a new alt.
  14. #14 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    Jan 2012
    Sturgis, MI
    Any guide about taken the alt off and apart? I like a project, as ive been at this for almost a year back when it was just a tiny squeak when idling but then went away as everything warmed up. When trying to resolve this, its making matters worse...
    Miles: 170-XXX
    Engine: 3.8L V6
  15. #15 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    alt is east to remove, take the pos cable off the battery,take the belt off, remove the thick cable bolted to the alt, and the plug. then take the 2 bolts off that hold it on the bracket. lift it off.
    when you put the new one on, the cable you bolt back on, do not make it super tight, snug, plus a 1/4 turn tops. the threads are a stud that are only soldered on, if over tightened it brakes free, and your out of luck.
    if you have a local re builder by you, they are usually cheaper than any parts store. most of these shops rebuild starters and alternators. sometimes they have them on a shelf waiting to be sold, (they want your old one, or charge a core charge) and sometimes you need to wait a few hours to have yours re built.
    if you do go to a parts store they will want your old one too, or they charge a core charge for it. so what i do is take it off at home, bring it to the store, make sure it matches up perfectly to the old one, then buy it. and no core charge because your leaving the old one there.
  16. #16 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    Jan 2012
    Sturgis, MI
    Ok so should i try to take my alt apart myself and check the bearings to see if its possible that could be my whole entire problem?
    Miles: 170-XXX
    Engine: 3.8L V6
  17. #17 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    no just get a replacement. if you have over 100,000 miles on the car and its original it was on borrowed time anyway.
  18. #18 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    I'm telling you it's the belt it can "look" fine but still be bad. That definitely sounds like belt slipping. I replaced one on a car a while back that "looked" fine but had a belt squealing issue and a new belt fixed it right up. But you can waste money on an alternator if you want.
  19. #19 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    he is right about the belt. they do have little gauges to see if the grooves have worn past where they are effective.
    when you cleaned it, did you see any missing grooves or large cracks?
  20. #20 Re: Obnoxious Squeal HELP!!! [Video Uploaded]
    Jan 2012
    Sturgis, MI
    No i didnt see any cracks whatsoever, no missing grooves either, though the sides on certain parts of the belt was kinda worn a bit. I guess ill try getting a new belt, worse case scenario is that it wont work and ill have to take the damn thing off, take it back to get my money back and play hell getting the old one back on and try something else. By the way, i do have about 155k miles on the car and i got the car at 133k miles.....Will let you guys know sometime tomorrow
    Miles: 170-XXX
    Engine: 3.8L V6
  1. Washer Fluid Not Pumping After Pump Replacement (PHOTO UPLOADED)
    By Adidasdude1989 in forum General Tech Discussion
    Last Post: 07-07-2012, 03:10 PM
  2. Loud obnoxious whine from supercharger
    By TheBeastGTP in forum General Tech Discussion
    Last Post: 03-27-2011, 10:45 AM
  3. squeal
    By dbean in forum Brakes/Suspension/Chassis
    Last Post: 10-18-2008, 04:22 PM
  4. Finally uploaded My New WS6 Hood Pics
    By DesQ27 in forum Visual/Body Modifications
    Last Post: 10-02-2008, 12:34 AM
