Thread: Hard steering under low rpms and low speeds.
Results 1 to 15 of 15
  1. #1 Hard steering under low rpms and low speeds.
    Dec 2010
    DMV
    Ok lately I've been noticing that under low speeds my steering is tight and stiff but soon as I tap the gas the pedal loosens up immediately. I've checked and refilled the fluid so thats not the issues. Any ideas? I'm leaning towards the power steering pump but want to be sure.
  2. #2 Re: Hard steering under low rpms and low speeds.
    HUDSON
    DEf. sounds like the pump. The steering in my car became more difficult to turn at low engine/vehical speed immiediatly after replacing my leaking power steering pump with a reman. unit from AZ.
  3. #3 Re: Hard steering under low rpms and low speeds.
    is the pump whining? like when you turn the wheels at idle standing still?
    is it harder to turn left vs right?
  4. #4 Re: Hard steering under low rpms and low speeds.
    GT Level Member GMCustomerService's Avatar
    Michigan
    Bluemagic,
    Sounds like the power steering pump. You may want to have your tech look at it to be sure.
    Keep us posted.
    Louis
    GM Customer Service
  5. #5 Re: Hard steering under low rpms and low speeds.
    Quote Originally Posted by GMCustomerService View Post
    You may want to LOOK AT IT YOURSELF AND NOT GET HOSED AT A DEALER.Keep us posted.
    Louis
    GM Customer Service
    Fixed.
  6. #6 Re: Hard steering under low rpms and low speeds.
    Apr 2012
    london
    Fixed.
    The steering in my car became more difficult to turn at low engine/vehical speed immiediatly after replacing my leaking pump with a reman.
    Dec 2010
    DMV
    Thanks you guys! I'll get it looked at today
  8. #8 Re: Hard steering under low rpms and low speeds.
    Jun 2012
    Did you ever fix this? I'm having the same problem.
  9. #9 Re: Hard steering under low rpms and low speeds.
    if you hear the pump whining like a bad pump does, its the pump.
    if its hard one way and easy to turn the other. its the rack and pinion.
    man i suck 3 edits:
  10. #10 Re: Hard steering under low rpms and low speeds.
    Jun 2012
    Hard to turn left, easy right. I just replaced, struts, tie rods, half shafts, brakes, belt and tires. Always something... lol
  11. #11 Re: Hard steering under low rpms and low speeds.
    racks bad
  12. #12 Re: Hard steering under low rpms and low speeds.
    yup it is.
    i had the same thing. i changed the pump and still had no power, it will start to get hard both ways soon enough. then i swapped my rack with a used one. works great still a year later.
    Dec 2010
    DMV
    Sorry guys forgot to update. It was the power steering pump replaced it but now it's leaking lol. Going to replace it again on Sunday
  14. #14 Re: Hard steering under low rpms and low speeds.
    Jun 2012
    Replaced the rack and pinion. All good now.
  15. #15 Re: Hard steering under low rpms and low speeds.
    Springfield Missouri
    I had my rack crack in half in the middle of the road. Trust me it was a fun fix.
  1. Won't start steering wheel hard.
    By fakir in forum General Tech Discussion
    Last Post: 04-06-2012, 07:40 PM
  2. Steering Wheel Shakes When speeds above 40 MPH
    By achurch7534 in forum Northeast
    Last Post: 12-22-2011, 07:48 AM
  3. hard steering
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2011, 10:04 AM
  4. Hard Power Steering at IDLE
    By Blownbyyou in forum General Tech Discussion
    Last Post: 03-12-2010, 09:59 PM
  5. HARD steering low RPMS
    By drunknmunky in forum Brakes/Suspension/Chassis
    Last Post: 10-06-2009, 07:17 AM
