Thread: Got the vacuum pump and gauges. Need the dryer, oil, and orfice tube, how much freon?
Results 1 to 9 of 9
  1. #1 Got the vacuum pump and gauges. Need the dryer, oil, and orfice tube, how much freon?
    Florida
    Got a reman compressor, still need to buy the seals. I want to buy the dryer, oil, orifice tube, and freon all at the same time so I can take advantage of Advance's VISA promo code, but I can't seem to find information regarding how much r134a the system will take after I pull a vacuum? How many oz's should I get when I purchase the remaining items? I already plan to get 8oz of 150 PAG oil. When I swap out the compressor, dryer, and orifice tube I put the PAG oil in the compressor (turning it over to saturate it) and in the dryer, then vacuum it? The vacuum draws out moisture and such, it won't draw out the oil I just put in there will it?
  2. #2 Re: Got the vacuum pump and gauges. Need the dryer, oil, and orfice tube, how much fr
    Dec 2011
    Central New Joisey
    The vacuum pump's sole purpose is to get rid of moisture that is trapped in the very air that is in the system the moment you break open the lines and allow it in. In a vacuum, water will boil at room temperature, so any moisture droplets will evaporate quickly in a pure vacuum. The oil will not.
    Florida
    Ok so oil then vacuum. How many cans should I buy of r134a?
    Sent from my SCH-I405 using Tapatalk 2
  4. #4 Re: Got the vacuum pump and gauges. Need the dryer, oil, and orfice tube, how much fr
    3 should be enough. Not sure of the exact amount but i'm thinking around 30 ish ounces.
  5. #5 Re: Got the vacuum pump and gauges. Need the dryer, oil, and orfice tube, how much fr
    St. Louis
    Should be a sticker somewhere in the engine bay. I want to say on the passenger side strut tower.
  6. #6 Re: Got the vacuum pump and gauges. Need the dryer, oil, and orfice tube, how much fr
    2.2 lbs IIRC
    Florida
    So should I put 2oz of PAG in the compressor and the rest in the dryer or should I put some in the orifice tube?
  8. #8 Re: Got the vacuum pump and gauges. Need the dryer, oil, and orfice tube, how much fr
    GTP Level Member
    springfield IL
    What brand of ac Compressor did u get..?? I had problems with the one i had... Ac wouldnt be very cold.. Put a new clutch on my old one, and its twice as cold now!!
  9. #9 Re: Got the vacuum pump and gauges. Need the dryer, oil, and orfice tube, how much fr
    Florida
    It's a Delphi. I snapped the shaft trying to replace the clutch on mine, so I just unbolted it and used some wire to attach it to the cradle out of the way and put a bypass in. Now that I have a new compressor, I'm going to remedy the situation.
  1. How do I remove the vacuum lines from fuel pump?
    By cmal37 in forum General Tech Discussion
    Last Post: 05-21-2012, 07:23 AM
  2. Freon/AC
    By jaydasparkz in forum General Tech Discussion
    Last Post: 07-21-2011, 05:28 PM
  3. AC only takes 7oz of freon?
    By SuperSport in forum General Tech Discussion
    Last Post: 07-07-2009, 06:39 PM
  4. orfice tube location?
    By pontiacman22 in forum General Tech Discussion
    Last Post: 10-22-2008, 06:13 PM
