Thread: 04 GTP, Has anyone replaced the resonator only ? Do I need adapters
Results 1 to 7 of 7
  1. #1 04 GTP, Has anyone replaced the resonator only ? Do I need adapters
    Jun 2012
    Potsdam
    The resonator on my 04 grand prix has holes and the check engine light came on. I want to fix with low cost options and the rest of system looks ok. Can I just remove and replace the resonator only? Any advice, thx
  2. #2 Re: 04 GTP, Has anyone replaced the resonator only ? Do I need adapters
    Apr 2009
    Fort Worth TX
    Put a straight pipe or a glasspack in there and be happy
  3. #3 Re: 04 GTP, Has anyone replaced the resonator only ? Do I need adapters
    Mar 2012
    Minnesota
    Yep, very simple, just cut out the resonator out and replace it with either pipe or a glasspack. If you just put pipe in when you get to higher rpms itll get raspy and if you put a glasspack in itll make the overall exhaust note louder. What code did the CEL read?
  4. #4 Re: 04 GTP, Has anyone replaced the resonator only ? Do I need adapters
    i picked up a glass pack for 22 bucks, bought a flange to mount to the cat, cut one tube off, welded the new flange on, and put it in.
    if you still have all factory pipes still you will need to have it welded in. mine was all replacement pipes, so i was able to unclamp the old res, and clamp in the new one. 2.25 i/d pipe.
    Cel might not be for the exhaust leak.
    Scan it.
  6. #6 Re: 04 GTP, Has anyone replaced the resonator only ? Do I need adapters
    Mar 2012
    Minnesota
    thats what i was thinking because ive had res out on friends 03 impala for 2 years and no CEL
  7. #7 Re: 04 GTP, Has anyone replaced the resonator only ? Do I need adapters
    Jun 2012
    Potsdam
    Thx for the responseS and pictures. I will scan it.
  1. Side post adapters!!!
    By ajoliver2010 in forum Audio, Security & Visual Electronics
    Last Post: 04-06-2012, 09:41 PM
  2. Speaker Sizes and Adapters in a 97 GTP
    By SlyBlackDragon in forum Audio, Security & Visual Electronics
    Last Post: 09-07-2011, 06:09 PM
  3. Anyone know anything about wifi adapters?
    By tayl5645 in forum Off Topic Discussion
    Last Post: 08-11-2011, 10:38 AM
