Thread: Need help!!
Results 1 to 12 of 12
  1. #1 Need help!!
    the desert
    when i try to turn on my car it doesnt start or crank. If i keeping messing with the terminals after about the 5th time of taking the negative cable off and putting it back on the car cranks and turns on but once that happens I have to keep pressing the gas or else the car will die. After this happens my cars idle is horrible and the rps jerk back and forth quickly. No check engine codes. I've had suggestions on replacing the iac valve but I havent got to it yet. With these symptoms what does everyone suggests doing?
    99 grand prix gtp
  2. #2 Re: Need help!!
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    Sound like a vac leak nd bad screw on ya battery
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: Need help!!
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Take out the IAC, push the bar and nipple into the IAC, put it back in the throttle body, leave unplugged and try to start car. If it stays running yeah IAC oh idle will be higher don't be alarmed.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  4. #4 Re: Need help!!
    the desert
    replaced the iac valve with a new one and problem still exists
  5. #5 Re: Need help!!
    Apr 2009
    Fort Worth TX
    Did you clean the TB?
    May be a huge vacuum leak or the closed loop fueling is messed up due to a sensor.
    Try unplugging the MAF and see if it idles better.
    If that doesn't work clean the TB.
  6. #6 Re: Need help!!
    the desert
    unplug the maf as in just the sensor or take the whole thing out? and i already tried cleaning the throttle body and nothing happend
  7. #7 Re: Need help!!
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by mcsddd View Post
    Remove the wire connector from the sensor and start the car.
  8. #8 Re: Need help!!
    the desert
    the rpms just went up to the 3 and stayed there. Its a brand new maf sensor
    Apr 2012
    Middletown DE
    I bought a maf from Napa once, box had right part number but wrong part inside. Same exact issues you're having.
    Sent from my Galaxy Nexus using Tapatalk 2
    1993 Oldmobile 88
  10. #10 Re: Need help!!
    the desert
    so you think its the maf?
  11. #11 Re: Need help!!
    Apr 2012
    Middletown DE
    could be. if you have a local junk yard go pick one up from there to test
    1993 Oldmobile 88
  12. #12 Re: Need help!!
    the desert
    could it be a bad 02 sensor?
