Thread: A/C compressor cluth wll not disengage.
Results 1 to 9 of 9
  1. #1 A/C compressor cluth wll not disengage.
    Apr 2012
    Indiana
    Hello everyone, I have a 97' Grand prix gt that I bought a few months ago, and the a/c has not worked at all since I bought it. The a/c compressor cluth would not engage or anything. So hoping to get lucky I went out today and bought some r-134a to recharge the system hoping everything would be fine. Well it's not .
    When I added the refrigirant everything seemed fine, the clutch on the compressor engaged and it started blowing cold air out of the vents. However the clutch didn't disengage at all. I pulled the relay and switched it with the horn relay to see if that was the problem, and same thing. As long as the a/c is on, the clutch is engaged all the time. It was 80 degrees here today, and the can I used said for that temp. fill to 50 psi, and I filled it to about 47. So I know it's not overcharged.. Any ideas? Any feedback will be much appreciated. Thank you.
  2. #2 Re: A/C compressor cluth wll not disengage.
    mine never turns off when the a/c is on. at least not that im aware of.
  3. #3 Re: A/C compressor cluth wll not disengage.
    Apr 2012
    Indiana
    Well, by design they are supposed to. lol It should cycle on and off as the a/c is on. If not eventually the compressor will probably seize up. The outer pulley on the compressor will always spin, but the clutch in the middle of the compressor should cycle on and off.
  4. #4 Re: A/C compressor cluth wll not disengage.
    it wont cycle off till the car is cold as balls then, just like a house window a/c, when the room gets cold the Thermostat turns off the compressor. so if your a/c is set to 60, and its not 60 inside the car, it wont turn off.
    i always have my windows cracked open so its never turning off for me. and works just fine, ice cold air.
  5. #5 Re: A/C compressor cluth wll not disengage.
    The blue guy is right, the AC clutch will turn on and off, because thats the way they work. Just because it turns off, doesnt mean the cold air stops flowing.
  6. #6 Re: A/C compressor cluth wll not disengage.
    It turns off when you turn the ac off right?
  7. #7 Re: A/C compressor cluth wll not disengage.
    Apr 2012
    Indiana
    Yes, it turns off when I turn the a/c off, it's just not cycling like it is supposed to while the a/c is on.. The cluth just stays engaged the whole time until I turn the a/c off
  8. #8 Re: A/C compressor cluth wll not disengage.
    Apr 2012
    Indiana
    Also I forgot to mention the Clutch also disengaged when I pulled the relay, so I know the relay is working correctly also
  9. #9 Re: A/C compressor cluth wll not disengage.
    It could also be the fact that it didnt work before because it had no R-134a in there and after only adding a little to get it going, its still not up to proper specs and pressures and thus the computer thinks its gotta keep going.
    I'd personally take it somewhere and have them do a simple AC system check, and see if there is a problem somewhere. Then if non are present fill with the proper amount of R-134a and then all should be good.
    Most places do cheap system checks this time of year.
  1. Starter motor wont disengage when engine is running 97 Grand Prix
    By Jacob Sexton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-29-2012, 02:59 PM
  2. how much oil to put in compressor?
    By mcsddd in forum General Tech Discussion
    Last Post: 06-08-2011, 04:56 PM
  3. Compressor
    By InfidelRebel in forum General Tech Discussion
    Last Post: 08-13-2009, 01:41 AM
  4. ac compressor help
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2009, 02:28 PM
