Thread: Griding/Clicking Noise at Idle Under Hood
Results 1 to 16 of 16
  1. #1 Griding/Clicking Noise at Idle Under Hood
    May 2012
    m
    So just a few days ago I started to notice a grinding noise under the hood of my 2000 Grand Prix GTP. It has gradually gotten worse, and now it is much louder than the normal engine noise produced by the car. I hadn't noticed it until my friend remarked, "Jeez man what did you do to your car? It sounds like a diesel." A few of my other friends then agreed. Upon starting my car there is a real loud grinding noise by the engine that lasts just over a second followed by a quieter grinding noise that continues during the entire time in park or idling. I have noticed that it diminishes slightly with the A/C off, sometimes more than usual. It does not grind if I am cruising along, at least noticeably, but as soon as I come to a stop it begins again. It seems louder in park as well. The car has a smooth idle around 800 rpm and it runs perfectly (besides a suspension issue I have yet to address, most likely a CV axle). Does anyone know what could cause this, as well as the things I might be able to do with very limited mechanical experience to solve this problem? Thanks a bunch
  2. #2 Re: Griding/Clicking Noise at Idle Under Hood
    AC Clutch is a good guess.
  3. #3 Re: Griding/Clicking Noise at Idle Under Hood
    I'd agree. Pop off the accessory belt and spin all the pullies by hand to see if any appear to have problems
  4. #4 Re: Griding/Clicking Noise at Idle Under Hood
    May 2012
    m
    Well I took it to a shop because I couldn't figure out what it was. They told me it was a broken flywheel and quoted me $1000-1100. Does this sound about right?
  5. #5 Re: Griding/Clicking Noise at Idle Under Hood
    Shop around. The flex you can get for $30-$50 from nearly any member. Hell I probably have one here. If I do..$35 to your door should make it happen.
    Then it's just lift the motor out enough to swap the flex. It needs to lift about 8-12 inches. Realistically it's like doing an engine swap, but easier.
  6. #6 Re: Griding/Clicking Noise at Idle Under Hood
    May 2012
    m
    Well how long would you expect the job to take a good mechanic? It would most likely take me forever and I'd probably mess some stuff up. Not to mention I probably don't have half of the equipment needed to complete the task. I just wanted to know if the flex plate / fly wheel seems like it would be the problem and that $1000 is a reasonable charge for a job like that. The car still shifts fine and I don't feel any power reduction or tranny slippage so I wasn't sure, but it did sound like the sound was coming from below the engine. If the part they order is somewhere between $50-100, could it really take 10-15 hours of labor?
  7. #7 Re: Griding/Clicking Noise at Idle Under Hood
    they are charging you so much because they dont want the job.
    keep shopping.
  8. #8 Re: Griding/Clicking Noise at Idle Under Hood
    May 2012
    m
    Well I just realized that my car doesn't even have a flywheel. I drive an automatic... Looks like I will be finding another new mechanic. I have absolutely THE WORST luck with cars and mechanics. A second opinion is always nice anyway.
  9. #9 Re: Griding/Clicking Noise at Idle Under Hood
    in this post are pics of the fly wheel, this is what you have in your car.
    http://www.grandprixforums.net/i-hea...tml#post822940
  10. #10 Re: Griding/Clicking Noise at Idle Under Hood
    you do have a fly wheel lol different kind for a manual trans, but you still have one. also called a flex plate i believe.
  11. #11 Re: Griding/Clicking Noise at Idle Under Hood
    May 2012
    m
    Well I'm aware that I have a flexplate and that a flexplate is essentially a flywheel but the mechanic told me he was ordering a flywheel for my car. Just seems like a big mistake for a seasoned mechanic.
  12. #12 Re: Griding/Clicking Noise at Idle Under Hood
    he was over priced anyway lol
    im sure he was using flywheel just as a reference, we all call it both things from time to time.
  13. #13 Re: Griding/Clicking Noise at Idle Under Hood
    May 2012
    m
    Alright thanks. What do you think would be a reasonable cost for the job?
  14. #14 Re: Griding/Clicking Noise at Idle Under Hood
    labor for a engine swap is usually 5 to $600. this is almost pulling a engine. but a lot less work over all like bill said.
    look for the shops that have engines laying on the side of their building, those guys do engine swaps and will have no problem do this kind of repair. a lot of shops dont want the hassle of swapping engines, so they throw out a big number so you go away, if you take the price, they are still making a lot more money so they will do it.
    save a few bucks and buy a used flex plate, i think bill offered you one for 35 shipped, thats a pretty good deal.(if he has one that is) and have the shop put it in, so your not paying for marked up new parts as well.
  15. #15 Re: Griding/Clicking Noise at Idle Under Hood
    May 2012
    m
    Thanks. I am taking it to a engine/transmission shop tomorrow. I am going to get a second opinion and have them fix it while I am out of town. I would be happy to buy the flexplate from Bill but since my GP is my only car, the repair is pretty time-sensitive. They said they would be able to have a flexplate in a day at $55-60 and with the labor, it should come to about $700. The guy was very knowledgeable and said he would have to take the starter out to verify that the flexplate is the actual problem. He was planning on dropping the tranny rather than taking out the motor.
    How do you guys think my flexplate cracked anyway? I stumbled upon an article yesterday that said GM improperly alligned the flexplate in their 3.8L motors so they wear down from age, but I just hope this flexplate isn't a sign of a failing tranny or bad starter as well.
  16. #16 Re: Griding/Clicking Noise at Idle Under Hood
    it just seems to happen to these cars, modded or un modded, they still crack.
    taking the trans out is another option to get it done, probably easier then pulling the engine out 1/2 way.
  1. Clicking Noise
    By Adidasdude1989 in forum Brakes/Suspension/Chassis
    Last Post: 04-14-2012, 02:18 PM
  2. Clicking noise with key on
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-09-2012, 01:57 PM
  3. clicking noise
    By haasarmy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-14-2011, 05:04 PM
  4. clicking noise during load
    By pur3vil in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2011, 07:43 PM
  5. clicking noise
    By whitegtp in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 05:11 PM
