Thread: 97-03 Climate Control Hack
Results 1 to 20 of 20
  1. #1 97-03 Climate Control Hack
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    I was thinking today about when I had my 99 GTP with the climate control. I had read on the other forum back in the day about this trick you could do with the CC. You press both knobs in at the same time and hold it for a few seconds then you can see your speedometer digitally on the CC screen. I think you could also get your trans temp and **** too. Do any of you guys do this, if so what else can you read on that?
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  2. #2 Re: 97-03 Climate Control Hack
    Banned
    Wichita Falls, Texas
    Yeah, it's pretty neat. There is a list somewhere that lets you know what all the settings are.
    I'm pretty sure it's on ClubGP somewhere. I'll grab it if no one else has found it by then.
  3. #3 Re: 97-03 Climate Control Hack
    Banned
    To enter diagnostics mode:
    Press and hold both the Driver and Passenger knobs in simultaneously until the display changes to read "-00". To change position, turn the Driver knob to the desired number and turn the Passenger knob one click to view the data for that position.
    Position Description US Observed on mine Canada
    -00 Error codes (List of Trouble Codes Below!)
    -01 (servo position) 103-107 43-162
    -02 (servo position) 128 120-202
    -03 (servo position) 150 162-194
    -04 CJ2 Fan Speed Low=15, 29, 44, 58, 71, 86, 110=High, CJ2 Unit will adjust to other increments as needed
    -05 (servo position) 93 88-191
    -06 (servo position) -152 00-252
    -07 (servo position) 00 0, 34-255
    -08 (servo position) -155 00-255
    -09 (servo position) 00 0, 23-255
    -10 ? 04 04
    -11 CJ2 Vent Mode 1=Def, 2=Bilevel, 3=Auto, 4=Lower, 5=Def+Lower
    -12 Engine Coolant Temp -60 degrees 80=104, 95=131, 100=140 Peak@135°F
    -13 Actual Vehicle Speed in MPH
    -14 (servo position) 00 21=0
    -15 ? 39 44
    -16 Radiator low fan turn on temp -106 207
    -17 Radiator low fan turn off temp 196 199
    -18 ? 50 51
    -19 (servo position) 162-169 40-172
    -20 Affected by cabin temp sensor 89 50-172
    -21 (servo position) 00 ?
    -22 Sunload Sensor -117 LIGHT=126, 218=DARK
    To return to normal operation, press the MODE button next to the Passenger temperature knob.
    This is a list of the Trouble Codes displayed by the CJ2 Unit.
    A two digit code indicates a current fault while a three digit code indicates a historic fault.
    Trouble Code Description
    00 No System Fault
    01 or 101 Inside Air Temperature Sensor Short
    02 or 102 Inside Air Temperature Sensor Open
    03 or 103 Ambient Outside Temperature Sensor Short
    04 or 104 Ambient Outside Temperature Sensor Open
    05 or 105 LH Electric Actuator Open or Short
    06 or 106 RH Electric Actuator Open or Short
    07 or 107 UART Serial Data Line Fault
    08 or 108 Solar Sensor Open
    To clear codes from the CJ2 Unit, press the A/C Mode button.
  4. #4 Re: 97-03 Climate Control Hack
    GT Level Member YoungGTP's Avatar
    Aug 2008
    Iowa
    can yoy swap out a 99 climate control for a 98 one. (swap the one he's talking about with the 3 dial one) i hate mine
    -98 GTP Thunderstorm
    Cai, 3.5 press on pulley, NGK TR6's, 3" to 2.5" exhaust, thrush glasspacks, drilled 180 t-stat soon-overkill pcm, fully ported sc, N* TB, and LQ4 MAF, Future- Full I/C, XP cam, s&s headers
  5. #5 Re: 97-03 Climate Control Hack
    SE Level Member crimpton's Avatar
    Aug 2008
    Portland, Oregon
    Quote Originally Posted by YoungGTP View Post
    The only difference I know of between the 98 and 99 is most of the 98's had a green display....... Got any pics?
  6. #6 Re: 97-03 Climate Control Hack
    GT Level Member Euro's Avatar
    Roselle, IL
    I think he's saying to swap out his 3 knob one, for the digital CC in which you can do this to.
    I've tried it with mine and couldn't get it to work. Ah well, that's what the HUD is for
    2000 Regal GS - 190k - Black over Storm Gray Metallic - 9" K&N/AL104's/Borla/GP polished tq stars/turd
    2009 Impala LT - 62k - Car Seat Mobile
    2000 Grand Prix GT - 96k - Sold/RIP
  7. #7 Re: 97-03 Climate Control Hack
    Aug 2008
    Iowa
    yea lucky me i dont have a hud either. ha
  8. #8 Re: 97-03 Climate Control Hack
    TDCRacing
    Guest
    Quote Originally Posted by Street Wolf View Post
    -10 ? 04 04
    -15 ? 39 44
    -18 ? 50 51
    00 No System Fault
    Very nice. Did not even know this.
  9. #9 Re: 97-03 Climate Control Hack
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    What knobs are we talking about? Driver and Passenger...?
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  10. #10 Re: 97-03 Climate Control Hack
    Feb 2008
    South Bend, IN
    The gray circular knobs/buttons on the dual climate control. I cant really remember what it looks like but its the knob on the far left and then the knob on the far right. but yea the driver and passenger knobs.
  11. #11 Re: 97-03 Climate Control Hack
    Jul 2008
    sumter,south carolina
    my 02 doesnt have knobs it has the lil things u slide up and down
    02 GTP with mods 05 GP for DD
  12. #12 Re: 97-03 Climate Control Hack
    Roselle, IL
    Yeah the digital/electronic dual climate stopped in 2000. This is the one they're talking about, press the two big round buttons together!
  13. #13 Re: 97-03 Climate Control Hack
    Donating Users kind153's Avatar
    Pittsburg, KS
    I'm not sure if I'm asking to right section/thread...but I couldn't find any related issue.
    I had 105, cleared it, and 105 again. I have been hearing a noise of the actuator keeps moving (trying to do something) that goes away when i turns on the fan and moves its direction a few times.
    Is this something I can fix/replace?
    Thanks,
    MK
  14. #14 Re: 97-03 Climate Control Hack
    Pittsburg, KS
    bump
  15. #15 Re: 97-03 Climate Control Hack
    Donating Users mystic231's Avatar
    Michigan
    Yes
    You have a bad actuator. There are two of them, one for each side. Call Ed Morad at Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts with your model year and he will fix you up with a warrantied used one. The actuator is held on by three screws and is a simple fix. My right side went out two years ago and the used one from Morad is working great and the price was superb.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  16. #16 Re: 97-03 Climate Control Hack
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    In my search for information on the dual climate control and the temperature actuator motor replacement, I figured I would bring back and old thread instead of making a new one since there are so many threads on this.
    My '99 has the driver side stuck to around 70 degrees or so while the passenger side works fine. The thing is that when I turn the temperature up to 90, the driver side will blow nice hot air, so I know the motor is operating. Is it a common thing for it to only operate partially? I would think if it failed, it would just be stuck on one position.
    I still don't understand how to read the diagnostic codes, either. I went all the way through "22" and wrote down all the corresponding numbers and never got anything that appeared to be a trouble code (01-08 or 101-108).
  17. #17 Re: 97-03 Climate Control Hack
    Oct 2014
    United States
    Quote Originally Posted by Euro View Post
    Is this CC unit compatible with later model years? IE, 2000-2002? Can the wiring be changed to make it work or does it need a different AC unit behind the dash?
  18. #18 Re: 97-03 Climate Control Hack
    Never Never Land
    It's been gone over before. You'd need the dash harness from a dual digi car in order for the climate control to work properly. You might also need the HVAC box. Not sure on that one. No one has ever done it to my knowledge. Good job on searching. Not many can do that. The last post in this thread was over 4 years ago if you didn't notice LOL
  19. #19 Re: 97-03 Climate Control Hack
    Oct 2014
    United States
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    Yeah, unfortunately, most of the problems I've googled have only been answered by ancient forum posts.
    97-03 Climate Control Hack Attached Images
  20. #20 Re: 97-03 Climate Control Hack
    Pittsburgh, PA
    Yep I've swap one into a 97 GT when I was completely rebuilding it....I can't remember if you need the entire HVAC box, but you will need the inner workings for sure. Since it is dual climate, each side operates independent with its own actuator. Basically you need to find a donor at a junkyard, gut the entire HVAC box and outer components, remove the wiring harness (All one piece which is connected to the fuse block under the hood and the brake module, etc), and then rinse and repeat on your vehicle. It's a bunch of work and a major undertaking.....is it worth it? I dunno, maybe. I did the swap because I did a total rebuild and wanted to get rid of all the 97 stuff that was becoming a pain...ie 4t60e, electronics, etc. The donor I found at the junkyard happened to have the dual climate so thats what i went with. This is not a Saturday afternoon job. You'll need plenty of room to spread out all the parts you'll have to remove. Good luck!
  1. Digital CLimate control
    By jacobmh27 in forum Visual/Body Modifications
    Last Post: 10-15-2009, 08:01 AM
  2. Outside temp gauge on climate control
    By 99prixgt in forum General Tech Discussion
    Last Post: 10-05-2008, 05:13 PM
  3. Automatic CLimate control lights.
    By RichCresci in forum Visual/Body Modifications
    Last Post: 08-15-2008, 09:35 AM
  4. Dual zone climate control
    By CT Tech in forum General Tech Discussion
    Last Post: 07-10-2008, 02:05 PM
