Thread: Air Bag warning light on after changing Fuse Block
Results 1 to 3 of 3
  1. #1 Air Bag warning light on after changing Fuse Block
    Aug 2012
    Arizona
    Thanks to those of you who answered about a week ago on replacement of a 2006 Grand Prix fuse block. I did get the exact block out of a salvage car and the exchange was not problem. Took 5 minutes...
    However, about 10 miles from the house my Daughter-in-law's air bag warning light popped on. Any thoughts on what may have caused that, and I guess I need a scan tool to check it out and/or turn off the light?
    Any info would be appreciated!
  2. #2 Re: Air Bag warning light on after changing Fuse Block
    St. Louis
    Maybe a bad fuse or loose wire? Sounds like the SRS system lost power maybe since that is the only thing you changed.
  3. #3 Re: Air Bag warning light on after changing Fuse Block
    Aug 2012
    Arizona
    Bad fuse...found it...think it may have been blown when I put it in. seems fine right now with new fuse.
  1. Replacing Underhood Fuse Block
    By Synergy LS in forum General Tech Discussion
    Last Post: 08-09-2012, 09:34 AM
  2. Inline fuse / fused power distribution block
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2010, 12:12 AM
  3. fuse block ?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 01:09 AM
  4. 04 Grand Prix Fuse Block map
    By btempelman in forum General Tech Discussion
    Last Post: 03-15-2009, 03:38 PM
  5. 04 GP Fuse Block Map - Power Window Circuit Breaker
    Last Post: 03-15-2009, 12:24 PM
