Thread: Car wont start!!
Results 21 to 40 of 68
  1. #1 Re: Car wont start!!
    Mar 2012
    NC
    Seriously, it works. It's only 60kV...it'll sting like hell but you certainly need to know. The fuel check is to push in the little schrader valve like I said in my first post.
  2. #2 Re: Car wont start!!
    OMG Jason. I'm surprised checking for fuel pressure doesn't involve drinking gas with a check like that for spark.
    Personally, I like to spend the $3 on an inline spark tester. It's a simple flashing light that tells you if spark is present. \
    A fuel pressure gauge will tell you about the pressure
    Injector pulse..that can be tested with a 194 light bulb.
    Ohio
    Could be alternator on its last toes. Did you do the relay trick?
  4. #4 Re: Car wont start!!
    I think this may be helpful to you. Since you keep mentioning the battery light etc.
    http://www.grandprixforums.net/know-...lls-63491.html
    If your spraying starter fluid at it got it running for a moment, then you are likely not getting fuel. I may have missed you answering if there is fuel pressure at the schrader valve or not. If there is pressure there, look to the fuel injector fuse. If the fuse is good, test for power at the injectors. If you have 12+ at the injectors, then there may be an issue causing the pcm to not turn on the injectors.
  5. #5 Re: Car wont start!!
    the desert
    i dont see how i would bend 85 and still be able to put the relay back in without breaking it
  6. #6 Re: Car wont start!!
  7. #7 Re: Car wont start!!
    the desert
    when i say the battery light stays on all the lights come on then they go off. but the battery light stays on thats why i kept bringing it up
  8. #8 Re: Car wont start!!
    the desert
    bent the 85 tab and the car doesnt start
  9. #9 Re: Car wont start!!
    the desert
    i tried cranking the car then pressed the schrader valve and nothing happend. No spray or dribble
  10. #10 Re: Car wont start!!
    Ohio
    do the relay. cuz youre not getting fuel. right now go do it then come back to us
  11. #11 Re: Car wont start!!
    Ohio
    hmmm
  12. #12 Re: Car wont start!!
    the desert
    if it helps. when i was first trying to start the car and it wasnt starting i could smell gas after. but now when i try to start the car i dont smell any gas
  13. #13 Re: Car wont start!!
    could be a dead fuel pump.
  14. #14 Re: Car wont start!!
    the desert
    but it starts sometimes just dies right after. If the fuel pump is dead would it even start at all?
  15. #15 Re: Car wont start!!
    sounds like its priming and then quitting maybe, you hear the pump when you turn the key to run?
    if your schrader valve has no fuel at all coming out of it, you have a fuel problem for sure, if the tab being bent did nothing, that bypasses the resistor, so that leaves the pump.
  16. #16 Re: Car wont start!!
    the desert
    well im tired of putting money into this car so looks like ill be parting it out. Thanks for everything everyone I really appreciate it.
  17. #17 Re: Car wont start!!
    dude a fuel pump cost like 30 bucks. dont quit that easy.
  18. #18 Re: Car wont start!!
    Pin 85 didn't work because Mike never reads what I type. The fuel pump resistor symptoms are starts and dies. Because the fuel pump would prime the cylinders.
    Now in the current case, you aren't getting fuel. So what you need to do is stick your finger on the schrader and tell us if there's any pressure there. If there's no fuel there, then I'll send you to check that the pump has power. If there is fuel there..then it's off to injectors.
    However..since I've already typed this once and it seems to have been ignored. I should probably go grab a beer and watch this thread for the next couple of days. Scotty..pass me a beer will ya buddy.
  19. #19 Re: Car wont start!!
    the desert
    i said earlier in the post that "i tried cranking the car then pressed the schrader valve and nothing happend. No spray or dribble"
  20. #20 Re: Car wont start!!
    Mar 2012
    NC
    Sounds like a fuel pump issue then. If you pull the access panel in the trunk and have someone try to crank it for you while you keep your hand on the fuel pump, you'll feel it vibrate if it is working. Or you can just try installing another one.
  1. Help help gtp wont start
    By GTPWINDYCITYBOI85 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2012, 10:12 PM
  2. new used pcm car wont start
    By izup69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-28-2011, 09:43 AM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. Car wont start
    By jluca in forum General Tech Discussion
    Last Post: 12-01-2010, 08:37 PM
  5. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
