Thread: What part is this? **overheating problems**
Results 1 to 20 of 20
  1. #1 What part is this? **overheating problems**
    SE Level Member MyPrixGT06's Avatar
    Weirton, WV
    I have found my self adding coolant a lot thi past week and still becoming hot. Today I investigated. This black 90° elbow is squirting out coolent.
    It feels metal and attached to the engine under the supercharger snout and connects to I think the water pump. What is the piece called and what do I need to do to repair it?
    2006 Pontiac Grand Prix GT-
    180 tstat and intake.
  2. #2 Re: What part is this? **overheating problems**
    Pic doesn't work but it's probably the coolant elbow that connects from the lim to the alt bracket.
  3. #3 Re: What part is this? **overheating problems**
    GT Level Member Deviq's Avatar
    SE WI
    Do a search for coolant elbow here on the forums, you'll find a "how to" to replace them. They are around $5 at auto stores
    Quote Originally Posted by zildjian102
    .. friggin trashy people. I did stuff with their daughter
  4. #4 Re: What part is this? **overheating problems**
    autozone has them for $3.99 in the help section behind the registers.
  5. #5 Re: What part is this? **overheating problems**
    Weirton, WV
    Thank u guys so much!!! I was thinking it might be apart of the water pump and may need a new one... Is it a metal or rubber piece?
  6. #6 Re: What part is this? **overheating problems**
    SE WI
    Not sure on your year car but would be 2 plastic elbows or 1 plastic and 1 metal cast as part of the bracket.
  7. #7 Re: What part is this? **overheating problems**
    He has an 06 it has 2 coolant elbows. They are plastic with rubber o rings on them.
  8. #8 Re: What part is this? **overheating problems**
    Dorman 47065
  9. #9 Re: What part is this? **overheating problems**
    Weirton, WV
    Ok well I replaced the elbows but now I think I found a much bigger problem... I refilled the coolant and warmed up the car, then started seeing bubble coming from under the supercharger...
    Its puddling just above the oil filler and below the supercharger. Is this a blown head?
  10. #10 Re: What part is this? **overheating problems**
    welcome to the leaking lim bolt club.
  11. #11 Re: What part is this? **overheating problems**
    Weirton, WV
    So maybe not a head gasket? Is this hard to fix?
  12. #12 Re: What part is this? **overheating problems**
    the only way to fix it is to take the s/c off and then the lim, install new gaskets and thread sealant on the lim bolts when re installing.
    chances are you head gasket is fine.
    google search for lifter in 33 minutes, its a vid of the job, you just dont have to take the rockers and lifters out, and there are write ups here too. its not all that hard.
  13. #13 Re: What part is this? **overheating problems**
    You shouldn't need a head gasket. The HG is about 4 inches from your bubbling. That's classic LIM gasket area.
  14. #14 Re: What part is this? **overheating problems**
    I live here. TLSheff's Avatar
    http://www.grandprixforums.net/video...es-2-3112.html
    How-To-Video of what you need to do.
    Post#2 in the link is the list of parts to replace everything while you have it apart.
  15. #15 Re: What part is this? **overheating problems**
    Yeah it's the lim. Easier to do in the 04+ cars so your in luck.
  16. #16 Re: What part is this? **overheating problems**
    Weirton, WV
    Well, superchargers off but I cant get the manifold off... I unbolted all the bolts but won't budge.. I hit it with a rubber hammer and gently with a heavy hammer and nothing..
  17. #17 Re: What part is this? **overheating problems**
  18. #18 Re: What part is this? **overheating problems**
    Weirton, WV
    Thank you so much. I did remove those, I didn't want to but put a pry bar between the side gasket and popped right off.
  19. #19 Re: What part is this? **overheating problems**
    Recount and make sure you have all 12 bolts out
  20. #20 Re: What part is this? **overheating problems**
    Ya make sure, first time, I almost went to get a pry bar when I realized that 1 bolt was gunked up so bad I didn't see it, my friend did.
    Last thing you want is a broken LIM
  1. Overheating
    By tmackster in forum General Tech Discussion
    Last Post: 06-18-2012, 06:39 AM
  2. 97 gtp overheating -_- help?
    By Leiliel666 in forum General Grand Prix Discussion
    Last Post: 03-15-2012, 03:15 PM
  3. Overheating problems.
    By Phrozen99 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2011, 07:42 AM
  4. Overheating?
    By Dr.Sherman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2011, 07:12 PM
  5. overheating
    By famouspork in forum General Tech Discussion
    Last Post: 05-27-2009, 09:22 AM
