Thread: Need help--heater randomly only works on high, DIC goes out when fan stops
Results 1 to 9 of 9
  1. #1 Need help--heater randomly only works on high, DIC goes out when fan stops
    GT Level Member 40th GP's Avatar
    Utah
    So I had this weird/random problem today. I was driving along and noticed the DIC went blank. Like totally blank (I have gone through it and replaced all bulbs awhile back). It then came back on a few seconds later and I didn't think anything of it, but then it did it again for longer. This time I noticed that when it went blank the fan motor also stopped working. When I rotated the fan to high/position 5, the fan would come back on and the DIC would light up. If I moved the knob back to the lower levels, the fan would turn off and the DIC would go dim. When I turn the fan knob all the way to off, the fan would turn off and the DIC would light back up.
    It did this randomly a few different times over about 20 miles, then it started working normally again. I read in one forum that it could be the blower motor resistor, but where the DIC would dim and light up in exact sequence to where the fan speed was and then it started working normally again I am thinking that rules that out.
    It also seems the ignition switch could be the culprit. However, I have not had ANY other symptoms--the key always comes out, the shifter always goes into park, etc. I do have the shift lock release solenoid zip-tied because it is not working, but I have not had any other ignition switch symptoms.
    I also still have a random situation where when I start the car the radio will not have any sound. I posted about this in another forum and never came up with a solution. The radio will light up and the EQ lights will bounce so I know it is receiving the audio signal (it is an aftermarket), but no sound will come out. However, if I probe the speaker outputs on the back of the radio, they have power. If I turn off the car and open the door, then wait a sec and start it again the radio will usually play normally. It has done this for the full year and a half I have owned the car. It will also stop producing audio sometimes if I change inputs (from radio to CD for example). It seems to be that randomly when the power source changes it will not play the audio, but turning off or changing the power will bring it back. Then about 2 weeks ago I had it at the tire shop and when I got in the car the radio was TOTALLY dead--no lights, no audio, nothing. It would however still give me the 'remove the faceplate' security beep after turning off the car. I was about to call the tire shop and demand they fix it, but the next day it was back to working. I bring up the radio issue because I wonder if it is related to the random issue from today. I did put my stereo in the wife's car and hers in mine, and my radio did not have this problem in her car, but hers still randomly did not have sound in my car. Therefore it is logical to assume that the wiring or something in my car is the issue. Don't know if this is related or helpful either, but the ABS light has been on the whole time I have owned the car as well (except for one day when it randomly went off for about 5 minutes), and the TCS is turned off by default (and I can't turn it on), I think because the ABS light issue.
    Anyway, any ideas? Are these issues related? Where should I start looking? Ignition switch? BCM? Wiring? Help...
  2. #2 Re: Need help--heater randomly only works on high, DIC goes out when fan stops
    Utah
    Any ideas?
  3. #3 Re: Need help--heater randomly only works on high, DIC goes out when fan stops
    SE Level Member 01grandpri's Avatar
    Oct 2015
    allendale michigan
    I have the same problem in my 2002 40th gtp!!! Was it the ignition harness?
  4. #4 Re: Need help--heater randomly only works on high, DIC goes out when fan stops
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Thread is 4 years old.................
  5. #5 Re: Need help--heater randomly only works on high, DIC goes out when fan stops
    Oct 2015
    allendale michigan
    I know lmfao I'm having the same problem....and don't nobody know what it is
  6. #6 Re: Need help--heater randomly only works on high, DIC goes out when fan stops
    Utah
    Quote Originally Posted by SubwayGuy View Post
    What does that matter--the problem is the same. Why not try posting something useful instead of pointing out something we can all see?
  7. #7 Re: Need help--heater randomly only works on high, DIC goes out when fan stops
    Utah
    Quote Originally Posted by 01grandpri View Post
    Yes it was the ignition switch in my case.
  8. #8 Re: Need help--heater randomly only works on high, DIC goes out when fan stops
    Apr 2015
    Quote Originally Posted by 40th GP View Post
    You'll figure it out one day lol.
  9. #9 Re: Need help--heater randomly only works on high, DIC goes out when fan stops
    Oct 2015
    allendale michigan
    Awesome! I'm going to give it a try this weekend then!
  1. Blower motor only works on high.
    By 99gpse in forum General Tech Discussion
    Last Post: 04-15-2012, 12:08 PM
  2. Is this how the heater core works?
    By TeacherCreature in forum General Tech Discussion
    Last Post: 10-06-2011, 06:28 PM
  3. AC / Heater Blower Fan only works on one speed.
    By FormulaW66 in forum General Tech Discussion
    Last Post: 05-24-2011, 05:42 PM
  4. Cruise control randomly works
    By mach158 in forum General Tech Discussion
    Last Post: 08-25-2010, 08:39 PM
  5. 99 GTP A/C works great, then stops, then works great again
    By stotzbotz in forum General Tech Discussion
    Last Post: 09-27-2009, 02:39 PM
