Thread: Upper motor mounts
Results 1 to 6 of 6
  1. #1 Upper motor mounts
    GT Level Member ShadowSwept's Avatar
    Kentucky
    So my engine was replaced (trans split in half, and apparently took the block with it) and now that the warranty is up I started tinkering under the hood and found some big disappointments.
    First, the EGR wasn't connected, which I knew about because it had been deleted from the previous engine and there's no longer a connector for it, but not only was it not plugged in, they removed the block off plate from the exhaust and bolted on the new EGR. The EGR mount and the LIM-side hose had split in half. I cleaned it up and reinstalled block-off plates, but that was just my first issue.
    Looking around, I found the pass. side upper engine mount was missing a bolt near the manifold, and was broken by the middle injector where the evap would mount. The UIM is missing a chunk around the bolt under the MAP. To top it off, I found oil residue in the throttle-body screen.
    Frustrated, I dropped the hood and walked away. The car runs alright, but these things are damaging my calm. There's nothing unfixable, but is there anything else I should be looking for that might be related to or causing these problems, or is it a case of blind mechanic?
    Also, since I have to replace the passenger side motor mount anyway, are there any options for a lower profile mount that doesn't swallow half the valve cover? Any advice here is appreciated.
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  2. #2 Re: Upper motor mounts
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by ShadowSwept View Post
    If the shop did all that who replaced your motor, I'd go back and tell them to fix it. That's ridiculous of them to do that.
    You can put on an L67 motor mount. It is still gonna cover the valve cover, but it's not gonna bolt to the LIM and make it hard to access.
  3. #3 Re: Upper motor mounts
    Apr 2015
    Looks like this:
    It will utilize the 2 studs on the side of head. You will not need any extra pulleys either.
  4. #4 Re: Upper motor mounts
    Kentucky
    That's exactly what I'm looking for, thanks!
    Any advice on the oil in the throttle body? I've never seen that before.
    2003 Grand Prix GT
  5. #5 Re: Upper motor mounts
    i got a spare l67 coil/dog bone mount for sale still. http://www.grandprixforums.net/threa...-1-2-L36-parts
  6. #6 Re: Upper motor mounts
    Apr 2015
    I'd pull the TB off and have a peak inside. My guess is the PCV valve is dumping oil in the intake. Unless that intake of yours is weeping oil in the engine.
  1. upper motor mounts
    By Akuch26 in forum Engine
    Last Post: 09-10-2014, 11:18 AM
  2. WTB Upper Poly Motor Mounts
    By 97AutoXVette in forum Wanted To Buy - Parts
    Last Post: 04-25-2014, 08:15 AM
  3. Need help with installing poly upper motor mounts!
    By M7x350z in forum General Tech Discussion
    Last Post: 04-17-2014, 06:16 PM
  4. Replacing Upper Motor Mounts : Help!
    By Pokealong1227 in forum General Tech Discussion
    Last Post: 03-02-2014, 03:18 PM
  5. Upper motor mounts
    By luckytii7 in forum Wanted To Buy - Parts
    Last Post: 08-19-2013, 07:16 PM
