Thread: a/c question. Please?
Results 1 to 11 of 11
  1. #1 a/c question. Please?
    SE Level Member Jessica729's Avatar
    Yukon Oklahoma
    I have a 2002 Grand Prix 3.8
    The AC works.. The problem is that it's dual climate control and the driver side stays hot most of the time. Occasionally it will cool off for a while, but it never gets very cold like the passenger side does. While having half the a/c is better than having nothing, it's no match for this Oklahoma heat. Plus, next Thursday the 10th, I'm having a baby, so I'd really appreciate any advice on this. Thank You!!
    ~~Jessica~~
    2002 Grand Prix GT 3.8 liter
    If it has tires or testicles, you're gonna have trouble with it.
  2. #2 Re: a/c question. Please?
    Jun 2010
    Bakersfield, CA
    I have the same problem... but in mine Drivers is cold passenger is hot. 2000 gtp. I'm hoping somebody helps you out... because I need help too!
  3. #3 Re: a/c question. Please?
    Jun 2010
    Bakersfield, CA
    I did come across this searching through the many ac issues...
    http://www.grandprixforums.net/f81/d...trol-4821.html
  4. #4 Re: a/c question. Please?
    Yukon Oklahoma
    Hey thanks. I sure hope this fixes my issue! It's HOT!
    ~~Jessica~~
  5. #5 Re: a/c question. Please?
    Jun 2012
    Kansas
    Quote Originally Posted by Jessica729 View Post
    Has anyone fixed the above problem. If they did please let me know too. My 99 blows cold on passenger side but warm on drives side
  6. #6 Re: a/c question. Please?
    Dec 2008
    Georgia
    I can't seem to get the link to work but I would like to see it. I have a 2000 GT with the dual climate control, and sometimes, when I get in it, it will read something crazy, like -38 degrees, and start blasting hot air even though it may be 80 degrees outside. Anyone see this before? Thanks.
  7. #7 Re: a/c question. Please?
    warm on the d/s can be low Freon, or a blend door actuator has quit working.
    this little f'er could be the culprit.
    in the pic on the left side with the line trough its hole. you also have one on the pass side.
  8. #8 Re: a/c question. Please?
    Jun 2012
    Kansas
    I just got it checked out yesterday and they checked for leaks. And filled it up I can turn it to hot and it warms up and then turn it to cold and it blows 65 on drivers side and 45 on pass side
  9. #9 Re: a/c question. Please?
    i just posted this in another thread, so here you go.
    next step is the blend door actuator.
    if you take this little bastard off and turn that small knob it sits over one way or another, you get full heat or full a/c. ( on that side only) driver side is fun to get to. you need to take off the plastic under the wheel, by your knees, then the steel knee bolster, 4 bolts i think, and the foot cover by your feet. if you look threw the front with a light you can kinda see this thing. it has 2 very small bolts that hold it in and they are kinda hard to get to, i used a nut driver to get the bolts out. the only real reason to take all that stuff off the front side, is so you can see what you are doing, you reach up from underneath to get to it.
    truth be told, mine are unplugged for a year now, i take it off and turn the knob where i need it, hot or cold, and then slide the actuator back on, no bolts, it stays put for me. im to cheap to buy another one. so im all jerry rigged lol
  10. #10 Re: a/c question. Please?
    Jun 2010
    Bakersfield, CA
    Ding ding ding! Mine was indeed a frozen blend door. Had it replaced before last summer and it's still going strong.
  11. #11 Re: a/c question. Please?
    Jun 2012
    Kansas
    Thanks for the info I'll try getting to it
  1. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  2. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  3. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
