i just posted this in another thread, so here you go.
next step is the blend door actuator.
if you take this little bastard off and turn that small knob it sits over one way or another, you get full heat or full a/c. ( on that side only) driver side is fun to get to. you need to take off the plastic under the wheel, by your knees, then the steel knee bolster, 4 bolts i think, and the foot cover by your feet. if you look threw the front with a light you can kinda see this thing. it has 2 very small bolts that hold it in and they are kinda hard to get to, i used a nut driver to get the bolts out. the only real reason to take all that stuff off the front side, is so you can see what you are doing, you reach up from underneath to get to it.
truth be told, mine are unplugged for a year now, i take it off and turn the knob where i need it, hot or cold, and then slide the actuator back on, no bolts, it stays put for me. im to cheap to buy another one. so im all jerry rigged lol
Thanks for the info I'll try getting to it
