Thread: Fan Question
Results 1 to 11 of 11
SG2000GTP Fan Question 06-09-2012, 09:44 PM
Fivefingerdeathpunch Re: Fan Question 06-09-2012, 09:51 PM
Rico Re: Fan Question 06-09-2012, 09:53 PM
SG2000GTP Re: Fan Question 06-10-2012, 09:09 AM
dsmuts Re: Fan Question 06-10-2012, 09:12 AM
SG2000GTP Re: Fan Question 06-10-2012, 10:34 AM
Scottydoggs Re: Fan Question 06-10-2012, 10:39 AM
SG2000GTP Re: Fan Question 06-10-2012, 05:56 PM
dsmuts Re: Fan Question 06-10-2012, 06:01 PM
Rico Re: Fan Question 06-10-2012, 11:39 PM
Scottydoggs Re: Fan Question 06-10-2012, 11:58 PM
  1. #1 Fan Question
    I just replaced my intake manifold gasket. Now the fans wont work. Everything seems to be hooked up. I replaced the water temp sensor on the bottom of the intake. My question is: Could that be the problem? Is that the sensor that tells the fan to come on? I will try in the morning turning on the a/c... That should automaticly turn on the fans. I think ? LOL Any way the car is a 2000 GTP. Thank You for the help.
  2. #2 Re: Fan Question
    Fan temps are 214 and 226.
    If you have bleed the system of air and its running fine and not over heating you wont see the fans kick on.
  3. #3 Re: Fan Question
    Apr 2009
    Fort Worth TX
    ...unless it gets to 214 degrees or the AC is turned on.
  4. #4 Re: Fan Question
    Thank you! I should have explained more. Yes the car is now running hot and at no time will the fans come on. I have not checked to see if the fans come with the a/c. The fusses are good and no probs before. I was wondering if it could be that new sensor I put in ?
  5. #5 Re: Fan Question
    New sensor should work fine but why did you change it in the first place? Did you bleed all the air out of the coolant?
  6. #6 Re: Fan Question
    I replaced it because I had the intake off and it was alot easier to do with it off. I am pretty sure that all the air is out I heater is blowing hot air. but please refresh my memory on how to bleed the air out of it. I know that thermostat housing has a bleeder screw on it how does that work?
  7. #7 Re: Fan Question
    i like to start the car, top it off, leave the cap open, let it idle till the fans come on, that way you know the t stat opened up, then open the bleeder screw a few turns till a stream of coolant come out. shut screw, top off rad if needed, shut the cap.
    it can take up to 15 minutes of idling to get all warmed up, so be patient.
  8. #8 Re: Fan Question
    Thanks for all the help it is workiing. I don't know what happend ...but it is fine now. Thanks!
  9. #9 Re: Fan Question
    it knew you were getting pissed and thought "maybe i'll just start working right" and it did.
  10. #10 Re: Fan Question
    Apr 2009
    Fort Worth TX
    I wish it always worked out like this.
  11. #11 Re: Fan Question
    gremlins...........
  1. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  2. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  3. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  4. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
