Thread: Door Ajar Switch Location In GP
Results 1 to 4 of 4
02WGTP Door Ajar Switch Location In... 04-18-2011, 02:49 PM
gpse2000 Re: Door Ajar Switch Location... 04-18-2011, 03:37 PM
02WGTP Re: Door Ajar Switch Location... 04-18-2011, 03:58 PM
twiggsta Re: Door Ajar Switch Location... 06-11-2012, 04:14 AM
  1. #1 Door Ajar Switch Location In GP
    Apr 2011
    Downriver, MI
    Hello Im having a issue with I believe my door ajar switch. Cause when I open the drivers door the intrior lights do not turn on, and when I get out of the car the radio stays on til until I open the pass door. I have tried searching and even looked on shopkey5 with no luck on the location of the switch to replace it.
    Thanks Mike
  2. #2 Re: Door Ajar Switch Location In GP
    GTP Level Member gpse2000's Avatar
    Apr 2011
    Fargo
    before you try to replace it try spraying the door latches with wd40
    My grandmas ford ranger had a similar problem it wouldnt sense when the door was shut and would say door ajar, i found on a ranger forum that wd40 would fix it so i sprayed the latches with wd40 and it works like new now with no probs
    2002 Denali Airaid MIT, Tint, 121k GARNET RED
    2006 GT S/C CAI, Plog, 3" DP, Flipped Mounts, DR STBs, SPO Grilles, SPO TIPS, Tint, Inlays, 120k BLEEN FOR SALE
    2000 SE 3.8 intake, dic swap, debadged, flipped mounts, rust mod 140k SILVERMIST SOLD
  3. #3 Re: Door Ajar Switch Location In GP
    Apr 2011
    Downriver, MI
    Ok thank you I will try that first before I buy a new switch.
  4. #4 Re: Door Ajar Switch Location In GP
    New orleans
    I'm bumping because i need to find this damned switch...
    did a search and got some info in chat box but couldn't find it...
    1998 gtp sedan drivers side
  1. Cooling Fan Switch location?
    By shaner in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-22-2012, 10:15 AM
  2. Door ajar?
    By Complecs in forum General Tech Discussion
    Last Post: 12-09-2010, 01:46 PM
  3. Hood Pin switch location?
    By cboth686 in forum General Tech Discussion
    Last Post: 02-12-2010, 05:36 PM
  4. Location of HUD switch on dash...
    By BlownBigBlock in forum Audio, Security & Visual Electronics
    Last Post: 09-23-2009, 12:40 PM
