Thread: Low Coolant Light
Results 1 to 16 of 16
  1. #1 Low Coolant Light
    Aug 2011
    Orland, Me
    My Low Coolant Light is on. I've verified it's not low, bled the system (let the air out) and it's still on. The next thing I will try is replacing the sensor. My question is does anyone have a recommendation on what brand to get? Should I just stick with an OEM product?
  2. #2 Re: Low Coolant Light
    USA
    I will pick up a AC delco one.
    here one I find quick on ebay
    ACDELCO OE SERVICE 10096163 Coolant Level Sensor | eBay
  3. #3 Re: Low Coolant Light
    Aug 2011
    Orland, Me
    Thank you. That's the cheapest I've found on for.
    First step is to clean it. Not replace.
  5. #5 Re: Low Coolant Light
    Aug 2011
    Orland, Me
    New situation, The low coolant light is on again and this time I'm leaking coolant. As best as I can tell it's leaking from the heater water inlet pipe. On the lower intake manifold side. I'm wondering if anyone has a wright up on this or may know the easiest way to replace it.
    Any and all help/suggestions are appreciated.
    Thanks
  6. #6 Re: Low Coolant Light
    http://www.grandprixforums.net/how-c...ows-49779.html theres plenty of threads that cover this job, a little searching is all you needed.
  7. #7 Re: Low Coolant Light
    Aug 2011
    Orland, Me
    Thank you for the link. My biggest problem was having no clue what to search for. I got the (heater water inlet pipe) part description from alldatadiy but found nothing that was helping me piece it together.
    Again thanks for the link.
  8. #8 Re: Low Coolant Light
    If you go to your local autoparts store with that part number they'll have what you need.
  9. #9 Re: Low Coolant Light
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    My car does the same thing. I just leave it lol
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  10. #10 Re: Low Coolant Light
    You can unplug the sensor and the light will go out.
  11. #11 Re: Low Coolant Light
    Aug 2011
    Orland, Me
    I've installed the 2 coolant elbows, filled the fluid, bled the system and all is well with one exception. The soft rubber T shaped vacuum piece right above the upper elbow broke. That appears to be a part neither Advance Auto nor NAPA carries.
    Does anyone know where that can be purchased? or is it a trip to a junkyard/dealer for me?
  12. #12 Re: Low Coolant Light
    what you need is a plastic T, advanced has them, they are small and white, come 2 per pack for 2 bucks, then get 3 inches of vac line.
    cut the old lines off the stock line on both sides of the snout T, then cut your vac line into 3, 1 inch pieces, put one on each line, and the snout, then put the T in the vac lines.
  13. #13 Re: Low Coolant Light
    Delaware, OH
    If the lights on and the coolant is full the sensor is most likely bad. They go bad all the time. Simplest fix is to unplug it to turn off the light. Or buy a new one.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  14. #14 Re: Low Coolant Light
    Aug 2012
    I'd say bad sensor as well
  15. #15 Re: Low Coolant Light
    GT Level Member GPTAFan's Avatar
    Sep 2012
    Maryville, Illinois
    Really? I need to do that.. my lights always on because I have a little air in the system. But an oversized radiator.. and my temp always stays at 180.so I nevermess with it.
  16. #16 Re: Low Coolant Light
    Yep I ran my 98 like that for a long time
  1. Low Coolant Light
    By Adidasdude1989 in forum General Tech Discussion
    Last Post: 01-31-2012, 02:56 PM
  2. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  3. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  4. coolant light
    By handirifle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 03:18 PM
  5. Low Coolant Light
    By Scott B in forum General Tech Discussion
    Last Post: 12-05-2008, 05:21 AM
