Thread: AEM wideband question?
Results 1 to 20 of 22
DaytonaGTP500 AEM wideband question? 06-07-2012, 03:43 PM
Bio248 Re: AEM wideband question? 06-07-2012, 04:07 PM
dsmuts Re: AEM wideband question? 06-07-2012, 05:14 PM
FoSHO99 Re: AEM wideband question? 06-07-2012, 06:10 PM
DaytonaGTP500 Re: AEM wideband question? 06-07-2012, 07:13 PM
rynoman03 Re: AEM wideband question? 06-07-2012, 07:23 PM
DaytonaGTP500 Re: AEM wideband question? 06-07-2012, 07:28 PM
gtpsleeper Re: AEM wideband question? 06-07-2012, 07:35 PM
DaytonaGTP500 Re: AEM wideband question? 06-07-2012, 07:50 PM
gtpsleeper Re: AEM wideband question? 06-07-2012, 07:59 PM
DaytonaGTP500 Re: AEM wideband question? 06-07-2012, 08:30 PM
DaytonaGTP500 Re: AEM wideband question? 06-07-2012, 08:28 PM
gtpsleeper Re: AEM wideband question? 06-07-2012, 08:35 PM
Fivefingerdeathpunch Re: AEM wideband question? 06-07-2012, 09:40 PM
matt5112 Re: AEM wideband question? 06-07-2012, 09:41 PM
Fivefingerdeathpunch Re: AEM wideband question? 06-07-2012, 09:42 PM
gtpsleeper Re: AEM wideband question? 06-07-2012, 10:00 PM
FoSHO99 Re: AEM wideband question? 06-07-2012, 11:13 PM
gtpsleeper Re: AEM wideband question? 06-08-2012, 02:46 PM
matt5112 Re: AEM wideband question? 06-08-2012, 03:26 PM
DaytonaGTP500 Re: AEM wideband question? 06-07-2012, 11:18 PM
DaytonaGTP500 Re: AEM wideband question? 06-07-2012, 11:30 PM
  1. #1 AEM wideband question?
    GT Level Member DaytonaGTP500's Avatar
    May 2012
    Iowa
    hey i just got a AEM uego wideband today and i was jus curious where the hell im supposed to be mounting the O2 sensor at on the headers, i dont know if it matters but i have speed daddy headers on it too. ive tried lookin around a little and havent really seen much but im sure i prolly overlooked it or somthin. all helps appreciated thanks.
  2. #2 Re: AEM wideband question?
    18" downstream from the downpipe is the 'recommended' place to mount the oxygen sensor.
    before the cat if you have one.
  3. #3 Re: AEM wideband question?
    I have mine in place of the ds o2. I've been told its to far away though
  4. #4 Re: AEM wideband question?
    Jan 1970
    Maquoketa, Iowa
    If your welding a bung in, just put it in the crossover pipe near the rear head, easy to get to and easy to wire up.
  5. #5 Re: AEM wideband question?
    May 2012
    Iowa
    yea i gotta weld in a new bung, and is it really good to just shove in the crossover pipe? cuz if so holy crap would that be easier. do you just put it like right under the throttle body or? also FoSHO99 i was curious if you know of anyone over in that area with a tuner that could tune my car for me? im originally from that area and movin back soon once i find a job back there, my dad lives in wyoming,ia and i come back often.
  6. #6 Re: AEM wideband question?
    Topeka, KS
    PM theothernick I think he's from IOWA.
  7. #7 Re: AEM wideband question?
    May 2012
    Iowa
    ok kool kool thank you i was gunna say right now im livin in des moines but ill drive anywhere in iowa. sooo thank you lol..... but ALSO it really is ok to shove that sensor in the crossover pipe?
  8. #8 Re: AEM wideband question?
    I wouldn think that place would be very accurate? If youre running a cat I think right in front of it would be the best spot imo.... when I put my AEM in I put it right before the last bend in the downpipe of my headers...
  9. #9 Re: AEM wideband question?
    May 2012
    Iowa
    yea deff not running a cat i have speed daddy headers with the catless dp. there alot like the slp with that nice lil low hangin u-bend in it. would it be good to jus throw it in there right after that u-bend on the down pipe or would you go right before the u-bend?
  10. #10 Re: AEM wideband question?
    I went right before my bend... maybe other widebands are different but I dont think these are as accurate if they are right there in the crossover...
  11. #11 Re: AEM wideband question?
    May 2012
    Iowa
    Thanks for all the help as usual guys very much appreciated
  12. #12 Re: AEM wideband question?
    May 2012
    Iowa
    That sounds like a prime location to me lol it'll be just as easy there as in the crossover sincee I got a lift to work with lol
  13. #13 Re: AEM wideband question?
    do a little more reading dont just take my advice for real... it may work fine either way or I may have done it wrong... just saying the suggestions of more are better than one or two...
  14. #14 Re: AEM wideband question?
    I put mine right here.
  15. #15 Re: AEM wideband question?
    I put mine on the top of that.
    Less likely to make love with a rock.
  16. #16 Re: AEM wideband question?
    I love rocks.
  17. #17 Re: AEM wideband question?
    thats a good place...
  18. #18 Re: AEM wideband question?
    Jan 1970
    Maquoketa, Iowa
    The front bank is not going to be much different from the rear bank, less likely to be a leak before the sensor and overall easier. You can do what you want but it's not going make or break you from 5hp.
    Stainless Steel Headers w/ Downpipe
    ZZPerformance - Stainless Headers #ZZ-304HDR-38
  19. #19 Re: AEM wideband question?
    Quote Originally Posted by FoSHO99 View Post
    but what if you have an issue in the rear bank? Your WB would read fine but the reading would be wrong right?
  20. #20 Re: AEM wideband question?
    Quote Originally Posted by gtpsleeper View Post
    You still wouldn't know.
    If the rear was running lean then you'd only see the average and enrich until back on target but then front is rich, rear is lean.
    Issue still present, but should be clear from spark plugs when you pull them.
    Our PCM's only see one "bank" so it shouldnt matter.
  1. wideband O2 placement question?
    By buickman104 in forum PCM Tuning
    Last Post: 05-10-2012, 09:41 PM
  2. Wideband PID
    By Sandman in forum PCM Tuning
    Last Post: 03-08-2011, 09:24 AM
  3. Wideband
    By Wrongwayislost77 in forum PCM Tuning
    Last Post: 02-28-2011, 12:51 PM
  4. Wideband Gauge Question
    By Bedwards in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2010, 04:31 PM
