Thread: "Grinding" feeling when car is coming down from shocks
Results 1 to 6 of 6
  1. #1 "Grinding" feeling when car is coming down from shocks
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    I don't really know how to explain this that well. Lets say that when my cars on the shocks at the highest point, when it starts coming down it feels like its grinding. The first time i felt it, it felt like the tires were hitting slightly hitting the top of the wheel well. I know its probably not that, but at this point i don't know what it is. Could it be maybe the exhaust piping is hitting the bottom of the car or something? So many people have told me different things and i have no way of telling what it could be.
  2. #2 Re: "Grinding" feeling when car is coming down from shocks
    GT Level Member GMCustomerService's Avatar
    Michigan
    GTLGDP,
    What is the year/model of the vehicle? Is this a regular or intermittent occurrence? Aftermarket equipment / modifications?
    Louis
    GM Customer Service
  3. #3 Re: "Grinding" feeling when car is coming down from shocks
    St. Louis
    Check your front strut mounts. If you pop the hood and take a look at the center nut and bounce the car, does the center rise up at all? Other than that sounds like it could be bad springs/struts.
  4. #4 Re: "Grinding" feeling when car is coming down from shocks
    Oct 2011
    New Jersey
    Quote Originally Posted by GMCustomerService View Post
    GTLGDP,
    Louis
    GM Customer Service
    2000 GTP. Happens every single time, only modification is a different air intake.
  5. #5 Re: "Grinding" feeling when car is coming down from shocks
    St. Louis
    Get under there and look for any signs of rubbing. If you see clean plastic or steel then you know what it is.
    You don't need to go see a "GM certified technician and drop $$$$" for something that you can most likely fix yourself w/ a little bit of investigating. Worst case scenario if its the springs and struts- get quick struts and swap them in. If those are the original struts/springs on that car then it's time to change them. Long overdue.
  6. #6 Re: "Grinding" feeling when car is coming down from shocks
    Michigan
    GTLGDP,
    Thank you for providing the additional information. I have researched your vehicle, however there are currently no known issues available based on your description. "FordMan77" offers possible troubleshooting advice. If you are unable to resolve this issue, I encourage you to consult with a certified technician for additional assistance.
    Please feel free to contact me privately if you have additional questions.
    Louis
    GM Customer Service
  1. lost "D" and "3" the car only move forward in 2nd
    By asite57 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2012, 11:17 AM
  2. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  3. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
