Thread: Wheel Bearings/Hubs
Results 1 to 14 of 14
  1. #1 Wheel Bearings/Hubs
    Jul 2008
    Des Moines
    Is there any kind of write up on this for a DIY replacement. I need to change all my bearings out. Is it a hard project? Any special tools needed? I have impact wrenches, jack stands, sockets, wrenches. Any things else I will need?
  2. #2 Re: Wheel Bearings/Hubs
    Oklahoma
    Nope, you got it all. Its a fairly simple deal. The hardest part would be getting the axle nut off but with your impact wrench that shouldnt be an issue, I believe the axle nut is a 36mm one. Remove the tire, remove the axle nut, then remove the three bolts the hold the bearing to the spindle I believe it is called and then reverse. Be careful of the wiring that is on the bearing and dont get it smashed with the axle shaft.
  3. #3 Re: Wheel Bearings/Hubs
    Hoffman/Schaumburg, IL
    Axle nut wasn't too bad for me, 2ft breaker bar + my mass beats every bolt I've met to date.......
    But yeah, just watch for the wiring, and you may need a press/slight tap with a hammer to get the axle to let go of the bearing, just don't hit too hard
  4. #4 Re: Wheel Bearings/Hubs
    Barksdale AFB, LA
    Everyone kept telling me how hard the axle nut is to come off. I was all ready. Had the socket and a three foot breaker bar for insurance. I got a good stance ready... set myself... and started to push. It came loose with the slightest pressure. Man did I feel like a dweeb.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Wheel Bearings/Hubs
    ^^LOL....but yeah, it def is easier than I thought it would be, just like the crank bolt.....
  6. #6 Re: Wheel Bearings/Hubs
    NE Ohio
    i used a breaker bar and a 2 foot cheater pipe to get mine loose, lol. extensions for the sockets are lifesavers if you keep the kuckel bolted on and change out just the hub itself.
  7. #7 Re: Wheel Bearings/Hubs
    SE Level Member alacran's Avatar
    Apr 2008
    Chicago, IL
    there was a write up somewhere on the web but i cant find it. you need red threadlocker on the hub bolts and use Timken. Autozone sells Timken.
  8. #8 Re: Wheel Bearings/Hubs
    Oklahoma
    I dont believe that you want to use red thread locker on those hub bolts. Ive replaced a few of those things and have never used thread locker of any kind and never had an issue. But if you use red it would be dang near impossible to get them back out give the location of them and the cramped quarters. As for Timken, if you can afford to get those, I too would recommend them.
  9. #9 Re: Wheel Bearings/Hubs
    Jul 2008
    Des Moines
    What is Timken? Also, are the rear bearings/hubs just as easy to do? I have to do the back drivers side along with replacing the ABS wire harness.
  10. #10 Re: Wheel Bearings/Hubs
    Barksdale AFB, LA
    Quote Originally Posted by bcrosby51 View Post
    What is Timken?
    It's a brand of car parts.
  11. #11 Re: Wheel Bearings/Hubs
    Jul 2008
    Poteau Oklahoma
    timken is like 104 dollars for one, I checked on them last night.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  12. #12 Re: Wheel Bearings/Hubs
    Jul 2008
    Des Moines
    Oh, I went used OEM from Morad.....I got all four strut/springs assemblys, 3 wheel bearings and the abs harnes for $370 shipped to my door. Can't beat that deal.
  13. #13 Re: Wheel Bearings/Hubs
    GT Level Member BackInBlack's Avatar
    Vermont
    I was told by a mechanic recently that Timken is just a name now. Imported crap. They used to be good parts, but now... Not so much.
    The GPs are long gone...
  14. #14 Re: Wheel Bearings/Hubs
    Barksdale AFB, LA
    Quote Originally Posted by BackInBlack View Post
    I've been driving on a Timken for over 25k miles and it's fine.
  1. Wheel Studs....
    By Vegas~Blown in forum Brakes/Suspension/Chassis
    Last Post: 08-30-2008, 12:47 PM
  2. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
  3. M90 Rotor Bearings
    By Cyko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 02:17 PM
  4. Rotor pack bearings
    By marchi1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2008, 05:36 PM
  5. Wheel hub?
    By Mikel2k7 in forum Brakes/Suspension/Chassis
    Last Post: 03-02-2008, 09:22 PM
