Thread: no rpm gauge and tcs light wont go off
Results 1 to 8 of 8
  1. #1 no rpm gauge and tcs light wont go off
    Jun 2012
    baltimore
    Can anyone help me I am trying to figure this out.
    When I start up my 01 gtp its fine after driving it for about 10 minutes or so the rpm gauge goes to zero and the tcs light comes on. The car is still running and shifts fine I can actually feel the traction control disengauge though.
    Any thoughts or ideas what this could be I have never really messed with electrical things on a car and there is no check engine light so I can't look up the codes
  2. #2 Re: no rpm gauge and tcs light wont go off
    Houston
    Its going to be your Crankshaft Position Sensor. Pretty soon, your car will start shutting off while driving. It doesnt usually throw codes until it goes out completely. Replace the sensor and be done with it.
  3. #3 Re: no rpm gauge and tcs light wont go off
    Jun 2012
    baltimore
    Thanks. Do you know if this is something not too bad to do myself? I have the tools a I'm pretty good with working on cars. I have never changed a crankshaft sensor though
  4. #4 Re: no rpm gauge and tcs light wont go off
    Houston
    You will need a puller to get off the harmonic balancer. Here is where the sensor is located.
  5. #5 Re: no rpm gauge and tcs light wont go off
    St. Louis
    Take a read through this thread. Should be all you need to get it done.
    http://www.grandprixforums.net/how-r...sor-60906.html
  6. #6 Re: no rpm gauge and tcs light wont go off
    SE Level Member Musclecarguy's Avatar
    London
    I had the same problem but mine also will flip out then go to zero. So I changed the sensor and its still doing the same thing. Im also noticing that i lose power once in a while. feels unresposive and powerless like a cavelier. Any help is appreciated.
    2002 Grand Prix GT (Push button start system, LED Tail lights, Flowmasters with Oversized dual round SS Tip, K&N Air Filter, Custom Projector Headlights with LED strip and HIDs, HID Fogs, 18" Chrome rims with Continental Extreme Contact DW summer tires, and a loud sound system) DD
  7. #7 Re: no rpm gauge and tcs light wont go off
    Feb 2010
    TN
    Quote Originally Posted by Musclecarguy View Post
    I had the same issue turns out it was the ICM which I had changed first when that did not work I went with the cps when it did it again I brought to the shop they checked it for 3 days (it was running fine for them, finally it did it) they said it was the icm old one was only 9 months old and it went again
  8. #8 Re: no rpm gauge and tcs light wont go off
    London
    Problem is gone. After I changed ICM. I got one from the wreckers for $30 out of a GP that had less mileage. And car runs like new again. No loss of responsiveness or a guage that flips out turning off the TCS. I found a website that does a walkthough to find out if it is the sensor or ICM. It was helpful and very easy to follow. Here is the link: Part 1 -GM 3.8L Ignition Module Test and Crank Sensor Test (3X, 18X). Hope this helps everyone in the future.
  1. E-brake light wont turn off need help!!
    By zjeylani in forum Introductions/Noob Questions
    Last Post: 07-25-2011, 06:07 AM
  2. e-brake light wont turn off
    By basballny2 in forum Brakes/Suspension/Chassis
    Last Post: 05-12-2010, 04:07 PM
  3. SES light just wont stop...
    By backinblackgtp in forum General Tech Discussion
    Last Post: 02-18-2010, 05:37 PM
  4. Glove box light wont turn off?
    By 98gpgt98 in forum Off Topic Discussion
    Last Post: 10-27-2009, 06:32 PM
  5. Tire Pressure light wont turn off.
    By Fivefingerdeathpunch in forum Introductions/Noob Questions
    Last Post: 09-25-2009, 10:40 AM
