Thread: Low Trac Light when leaving reverse and some other transmission questions...
Results 1 to 5 of 5
Threaded View
  1. #1 Low Trac Light when leaving reverse and some other transmission questions...
    Apr 2012
    Suffolk, NY
    I have only been driving my (new to me) GTP for a month or so and I have to say I love every second of it. I clocked about 2,000 miles this month mostly in longer distance jaunts to work, but even around town this thing is awesome.
    However, there are a couple concerns I hope you guys/gals can shed light on. I will start with my main issue then I will digress.
    1) When backing out of my driveway/parking stall and putting the transmission selector from Reverse into Drive the "LOW TRAC" lights up on the DIC. I don't know if I am crazy but it seems to also hum a little bit like a kind of a vibration noise? I don't have a clue why it does this and it does not happen every time I reverse. The light shuts off within a second or two and the car seemingly runs fine.
    2) How much play does your transmission have when it is put into Park? Also when put in Reverse from Park? I feel like when I park the car even without it being on any incline the car moves a solid 3"-4" forward or backwards before before the transmission pawl stops it from moving. Therefore I have been setting the ebrake on all surfaces because of this. I have always done this on hills because I drove manual for so many years.
    3) This is probably directly connected to #2 but how much does your GP move forward or backwards when you put it into reverse or drive from park? Mine sometimes jumps abruptly like a "hard" shift...but then most of the time it does not.
    I know my paragraphs seem vague and cryptic but I am wondering if I am going crazy. I am coming from driving a new GMC Sierra 1500 that was smooth as butter in the engine/tranny department. I understand this car is 10 years old so bear with me and my concerns. I am hoping I just need mounts and/or bushings to tighten things up but don't know where to start .
  1. transmission reverse problem
    By fremmy182 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2011, 09:39 PM
  2. ABS light on, Trac Off light on, New hubs all around
    By tdm571 in forum Brakes/Suspension/Chassis
    Last Post: 06-12-2011, 07:44 PM
  3. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  4. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
  5. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
