Thread: Car wants to die after overkill install..
Results 1 to 19 of 19
  1. #1 Car wants to die after overkill install..
    May 2011
    wisconsin
    After I installed my overkill pcm my car ran fine then three days later I started it up and it turned over fine, put it in drive and pushed the gas pedal and it bogged down and almost died... Now everything my car sits for a long period of time (6+ hours) it does the same thing. One time my car actually died and I had to put it into park and restart my car... What the hell is happening?... Did I really just waste 250 dollars on a pcm?
  2. #2 Re: Car wants to die after overkill install..
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    sensors might be learning and resetting it tool my new pcm a few hours of driving to run smooth after my top swap
  3. #3 Re: Car wants to die after overkill install..
    May 2011
    wisconsin
    Quote Originally Posted by Wisconsingrandprix View Post
    I put my overkill in last friday. It started this problem three days after that and hasn't stopped...
  4. #4 Re: Car wants to die after overkill install..
    Aug 2011
    roun here
    check sensors might be the maf mine went rite after i did my top swap
  5. #5 Re: Car wants to die after overkill install..
    May 2011
    wisconsin
    Maf is within spec
  6. #6 Re: Car wants to die after overkill install..
    contact will at overkill and explain your problem. he can try and help you.
  7. #7 Re: Car wants to die after overkill install..
    Aug 2011
    roun here
    did you do anything to the car??
  8. #8 Re: Car wants to die after overkill install..
    May 2011
    wisconsin
    3.6 pulley, 104s, 180 stat, ssac headers, high flows cat, res delete, cai. All was listed for the pcm
  9. #9 Re: Car wants to die after overkill install..
    Texas
    Put in your old PCM and see if the problem goes away. It will help to at least isolate the PCM as the issue.
    85 Corvette
    01 TA
    03 Z06
  10. #10 Re: Car wants to die after overkill install..
    Out West
    Sounds about right.
    Whine with your Cheese?
  11. #11 Re: Car wants to die after overkill install..
    May 2011
    wisconsin
    I'll do that and post back later with the result
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    Mine does the exact same thing. Switch from reverse to drive and give it has and it just about dies. Drives great other than that.
  13. #13 Re: Car wants to die after overkill install..
    Banned
    CT
    250 bucks for a canned tune?!?!?!? Holy crap! I think the price for my custom tuning is going up...
    Unhook your battery for awhile and try again.
  14. #14 Re: Car wants to die after overkill install..
    Quote Originally Posted by SnowFlake View Post
    That includes a core charge of 100 or so.
  15. #15 Re: Car wants to die after overkill install..
    May 2011
    wisconsin
    Yeah 150 if I return my old pcm but I'm keeping mine just incase
  16. #16 Re: Car wants to die after overkill install..
    Aug 2011
    roun here
    any luck???
  17. #17 Re: Car wants to die after overkill install..
    May 2011
    wisconsin
    Took overkill pcm out and car ran fine. Put it back in and my gauges stop working when they want to, gas mileage plummets and it still wants to die apon first take off...
  18. #18 Re: Car wants to die after overkill install..
    Ocala, FL
    Hi.
    Quote Originally Posted by szalajka05 View Post
  19. #19 Re: Car wants to die after overkill install..
    May 2011
    wisconsin
    Quote Originally Posted by codyAK View Post
    Hi.
    Lol...
    I emailed him yesterday and still waiting on a reply
  1. Overkill pcm install help?
    By szalajka05 in forum General Tech Discussion
    Last Post: 11-13-2013, 02:21 AM
  2. overkill pcm
    By blown gt in forum PCM Tuning
    Last Post: 09-12-2013, 07:53 PM
  3. overkill, zzp
    By 2001goldGTP in forum PCM Tuning
    Last Post: 01-11-2013, 02:11 PM
