Thread: What are these 2 o-rings? (from gasket kit)
Results 1 to 9 of 9
  1. #1 What are these 2 o-rings? (from gasket kit)
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    need help locating where these 2 o-rings go..have any idea?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: What are these 2 o-rings? (from gasket kit)
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    kit for what more info plz
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: What are these 2 o-rings? (from gasket kit)
    Jul 2011
    Michigan
    head gasket kit from autozone..felpro
  4. #4 Re: What are these 2 o-rings? (from gasket kit)
    Sep 2012
    bridgeport,NY
    just the hg or the lim too
  5. #5 Re: What are these 2 o-rings? (from gasket kit)
    Those should be the same size as the coolant elbows. We typically recommend replacing the entire elbow, and the manufacturer often gives you new rings.
  6. #6 Re: What are these 2 o-rings? (from gasket kit)
    Jul 2011
    Michigan
    It came with 2 orange o-rings for the elbow bill, and 2 yellow ones that i put on the LIM. These 2 black ones are about the same size but one is thicker.
  7. #7 Re: What are these 2 o-rings? (from gasket kit)
    St. Louis
    PCV Valve?
  8. #8 Re: What are these 2 o-rings? (from gasket kit)
    You have two elbows.
    PCV should only have one on a charged motor. If this was a fel pro set, read the box. It'll tell you what they are expecting.
  9. #9 Re: What are these 2 o-rings? (from gasket kit)
    Feb 2008
    I believe one is for the PCV valve, and the other is for the vacuum tree on top of the SC.
  1. Gapless rings
    By DJNight2k in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2012, 11:43 PM
  2. HELP! LIM Gasket, Injector O-rings, Valve Cover Gaskets.....
    By Jones in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2012, 12:40 AM
  3. Does 1997 GTP SC have PCV o-rings ?
    By GTP in RTP in forum General Tech Discussion
    Last Post: 12-15-2011, 08:23 PM
  4. Centering Rings on my new 18's
    By cboth686 in forum Tires & Wheels
    Last Post: 05-09-2009, 12:59 AM
