Thread: Does 1997 GTP SC have PCV o-rings ?
Results 1 to 20 of 27
  1. #1 Does 1997 GTP SC have PCV o-rings ?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    PCV valve is on top held on by plate and 2 screws, I removed and replaced valve, did not see any o-rings on it ?
    1997 Red GTP 182000 miles stock
  2. #2 Re: Does 1997 GTP SC have PCV o-rings ?
    Omaha, NE
    There should be a gasket under that plate, I don't think it has o rings though.
  3. #3 Re: Does 1997 GTP SC have PCV o-rings ?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Gasket was there, in good shape. Still chasing P0171 though.
    Cleared the p0441 , previous owner had vacuum hoses routed wrong.
    Had the vacuum port in the tb hooked directly to the vapor canister.
    He then had the evap switch and soleniod hooked in a loop.
  4. #4 Re: Does 1997 GTP SC have PCV o-rings ?
    Omaha, NE
    CausesA code P0171 may mean that one or more of the following has happened:
    •The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
    •There could be a vacuum leak downstream of the MAF sensor.
    Source: OBD-II Trouble Code: P0171 System Too Lean (Bank 1)
  5. #5 Re: Does 1997 GTP SC have PCV o-rings ?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    I cleaned the MAF again today, still getting code. Previous owner did have an oiled air filter. I replaced with Fram paper filter. MAF looks new, however it has a part number sticker on it that says "Remanufactured" and I know those can be bad. No vacuum leaks that I have found yet.
    Also changed fuel filter, cleaned IAC .
  6. #6 Re: Does 1997 GTP SC have PCV o-rings ?
    Omaha, NE
    I would swap that remanufactured maf and see if that makes it go away.
    Do your RPMs bounce?
  7. #7 Re: Does 1997 GTP SC have PCV o-rings ?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    RPM's are fairly steady on tach when idling, some stumbling.
    What would be the cheapest way to swap out the MAF , don't have another one laying around.
  8. #8 Re: Does 1997 GTP SC have PCV o-rings ?
    Omaha, NE
    If you don't have a friend with a 3800, take a couple from the junkyard.
  9. #9 Re: Does 1997 GTP SC have PCV o-rings ?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    I will give it a try. thanks
    BTW , I have never seen this car throw a MAF code, can it be bad and no codes?
  10. #10 Re: Does 1997 GTP SC have PCV o-rings ?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    I unhooked the MAF, engine runs fairly smooth. Of course i got P0102 bad MAF signal. However the P0171 went away. Need to make it to JY to get another MAF to swap out. Does the P0171 going away mean it was the problem ? or is it just running in limp mode and the P0171 will come back even with another MAF ?
  11. #11 Re: Does 1997 GTP SC have PCV o-rings ?
    Bunnell, FL
    mine does from 40 - 48 at half throttle
    is this a bad maf or.....
    I'm a Sex Offender
  12. #12 Re: Does 1997 GTP SC have PCV o-rings ?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    mine bounces sometimes with key on ,engine off prior to starting.
    Bounces up and down a little off 0 , told this is normal ?
  13. #13 Re: Does 1997 GTP SC have PCV o-rings ?
    Nov 2011
    south carolina
    Quote Originally Posted by GTP in RTP View Post
    Having the vacuum straight to the canister can throw ya lean codes (your P0171).
  14. #14 Re: Does 1997 GTP SC have PCV o-rings ?
    Nov 2011
    south carolina
    P0171 doesn't throw if you're throwing a MAF code. There are several others, other than MAF, that will prevent the P0171 too.
  15. #15 Re: Does 1997 GTP SC have PCV o-rings ?
    Feb 2009
    flintnasty MI
    For the record, the PCV valve should have an oring on the "fat" part of it, as it fits down into the goofy plastic strainer.
    Also, 97s have a mess of tubes all over so make sure none of them are broken or cracked.
  16. #16 Re: Does 1997 GTP SC have PCV o-rings ?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Ok, I did not see a plastic strainer, I have the pcv that is on top the engine held on by 2 screws and a plate holding down a spring. Does that type have a strainer ? Any idea on size of o-ring ? Don't want to pay dealer for whole kit?
    No chit on a lot of tubes, i have been checking them.
    Rock - I cleared the misrouting evap hoses and that cleared the p0441, down to only p0171 now.
  17. #17 Re: Does 1997 GTP SC have PCV o-rings ?
    Nov 2011
    south carolina
    GTPinRTP, I think darkhorizon is talking non supercharged.
  18. #18 Re: Does 1997 GTP SC have PCV o-rings ?
    DH is talking supercharged. But unless you lean over and look into the hole, you'll never see the strainer.
    You can barely see it from below as well. See the thing in the hole
    that's the strainer. Anyhow one o-ring on the bottom piece of the pcv and seal the top cover.
  19. #19 Re: Does 1997 GTP SC have PCV o-rings ?
    Nov 2011
    south carolina
    I figured he was referring to the non superchargerd because he typed "as it fits down into the goofy plastic strainer." The PCV valve doesn't fit down into anything plastic on the supercharged engines I've been into and the o ring on the PCV valve seals against aluminum. The plastic piece in the hole has always been below the pcv valve.
  20. #20 Re: Does 1997 GTP SC have PCV o-rings ?
    Yeah, but we'll cut Scott a little slack on the fits into the strainer since TMK the NA doesn't have anything in there at all.
  1. AC Compressor O Rings Picture
    By mainecrab in forum General Tech Discussion
    Last Post: 05-22-2011, 08:02 PM
  2. Fuel Lines O rings
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-05-2010, 08:45 PM
  3. Injector 0-Rings
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-28-2010, 08:55 AM
  4. Hubcentric rings? used for wat?
    By keredwtf in forum Tires & Wheels
    Last Post: 07-14-2009, 02:57 PM
  5. Centering Rings on my new 18's
    By cboth686 in forum Tires & Wheels
    Last Post: 05-09-2009, 12:59 AM
