Thread: DIC blinking "0"
Results 1 to 12 of 12
  1. #1 DIC blinking "0"
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    pretty sure i picked up a regular dic without boost level and performance shift, it came out of a junk yard gtp but seems it was replaced in that car too. had a trac button with trac off and low trac thats it, rest is displayed in display.
    hooked it up replaced burned out bulbs. it does not read mileage or oil life or anything, just has a blinking zero.
    any way to calibrate?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: DIC blinking "0"
    Ohio
    no 97 takes only a 97 dic.
    98-03 take the same.
  3. #3 Re: DIC blinking "0"
    Texas
    There was no tracation control in 97. The PCM won't be able to communicate with that DIC. You will need a 97 specific one.
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: DIC blinking "0"
    Mar 2012
    Dallas
    dang, alright thanks
  5. #5 Re: DIC blinking "0"
    Mar 2012
    Dallas
    so i went to the junk yard again, 97 gtp has the TCS button, 2 other 97 GT's had TCS button. any clue as to why, if the 97 year did not come with traction control?
    The Boss Iceman6669's Avatar
    Jun 2011
    My 97 does not have a TCS button.
    2011 F-150 Yote powered
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Quote Originally Posted by Iceman6669 View Post
    X's 2
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  8. #8 Re: DIC blinking "0"
    Because it wasn't an option back then as the GTP model was just an add on to a GT...as a supercharged package. The GTP wasn't a specific model until '98.
  9. #9 Re: DIC blinking "0"
    Houston
    I found a pic of my old 97. It had a TCS button?
    EDIT: Nevermind, yall are talking about the digital dic.
  10. #10 Re: DIC blinking "0"
    Has everything to do with what month the car was made! I just pulled an engine and trans from a 97 to put in my 97 gtp coupe and the engine i pulled had the 98 and newer supercharged and i fixed some of the vac lines for everything to work. My DIC in my coupe now is also blinkin 0 but its intermintent I can see the dic boost guage working but the performance shift doesnt light up either. My guess for my own car is i have a few electrical issuses to sort out and as for the 97's yeah what others said GTP was and option. I belive mid year they went to the 98 style setup. When I go back to Oslo and get a chance to look at the car I got the engine from Ill double check the tag on the door to see what the month and year it is and compare it with the tag on the door of my GTP coupe. Im sure both are 97 but Im willing to bet they are like 8 months apart or something.
  11. #11 Re: DIC blinking "0"
    Mar 2012
    Dallas
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    i never get the boost gauge or performance shift light. i have tried 2 model numbers.629E and 629F last 4 digits
  12. #12 Re: DIC blinking "0"
    Jan 2012
    Philadelphia
    my 97 GTP has performance shift, boost gauge, and no traction control, (had) the 97 s/c replaced it with newer gen 3, mine is an earlier model its February 1997
  1. lost "D" and "3" the car only move forward in 2nd
    By asite57 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2012, 11:17 AM
  2. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  3. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
