Quote Originally Posted by hitman92499 View Post
Use a wiring diagram to locate all the things on the circuit. I like to use a 194 bulb plugged in where the fuse would be and unplug things until the little 194 bulb goes out. Being a lighting circuit, check tail light sockets for corrosion due to delaminated tail lights.
tail lights?
Quote Originally Posted by sseilmnop View Post
Got anything metal in the trunk? Had something blow my fuse once when it skid in the trunk. You have a wire somewhere that is pinched or rubbing on metal somewhere.
and there may be metal in the trunk not sure because its a friends car. but it was weird it happened out of no where. he wasn't even on the brakes when it happened. yea thats what i figured it was a wire grounding out
