This code popped up yesterday. I cleared it and looked it up online. The code means my car is idling higher than expected. I checked & it was idling at around 800-900rpm. Possible problems are; vacuum leaks, bad pcv,bad IAC Valve, failed EVAP system, leaky egr(I dont have one).
As for vacuum leaks, I dont have any leaks. I've wasted two cans of carb cleaner looking for one. I Just wasted $40 replacing the IAC valve. It fixed nothing. I took the pcv out, & found it covered in oil. I cleaned it off, put it back together, and sealed it with rtv, since I didnt have a pcv gasket. After doing that my car started idling even higher at 1100-1300rpms. Should I go ahead and assume its the pcv? How would I know if the problem is a failed evap system?
