Looks like I may need to tackle the LIM gasket issue.
Couple weeks back, I had to flush the heater core, due that it was clogged with the Dexcool/Glycol clay like material. I was successful in getting the heater core unplugged. However I'm still dealing with an overheating issue when driving at slow speeds or idling in traffic. I thought it was an air issue, due to the fact that, if I got on it while driving or revved the engine up the temp would come back down.
I went and bled it again and air did come out from the T-Sat housing.When I looked down into the radiator I could see it was below the outlet for the lower rad hose. But I attributed it too having air in the system. So I topped everything off and marked the expansion tank to see if I'm loosing any coolant. I changed the oil as well to see if it was milky at all. The oil was black/brown, no signs of coolant in with the oil.
When I was bleeding the system, I noticed that I had some Dexcool stains on the top of the tranny on both sides. I followed them up the best I can and it looks like it's leaking in the valley of the LIM.
I've been reading everything I can regarding the LIM and Intake failures. (Mine is a 2004 GT1 with the aluminum intake). However I still have a couple of questions.
1. Is it necessary to replace the Intake manifold gasket for the Aluminum intake? Some posts I've seen it mentioned they can be reused. Is this true or is it better practice to just replace it?
2. Instead of RTV, Can I use the copper permatex sealant for the 4 corners on the LIM? Only reason I ask is that I already have a tube of it.
3. Is the EGR stovepipe still as issue with the newer aluminum intake? Does it burn through the gasket or was it limited to the plastic intakes?
4. Can I use the copper permatex on the coolant elbows as well during reassembly?
Another general question I have about the bleeding process. Wondering if you can explain it to me.
Since the coolant flows from the top of the engine, through the thermostat, into the radiator and into the water pump. Once the thermostat closes and no coolant is flowing into the radiator. Wouldn't the suction from the pump completely empty the radiator and cause air to be introduced into the system again?
The reason I ask is when I was bleeding the system and the thermostat was closed. I opened up the bleeder and no coolant came out. Even if squeezed the hose nothing came out. It was like the upper hose was completely empty. Once the thermostat opened and coolant flowed, air bubbles did come out from the bleeder.
Am I doing the bleeding process incorrectly? I have the cap on during all of this.
