Thread: Loud Screeching Sound
Results 1 to 5 of 5
  1. #1 Re: Loud Screeching Sound
    it sounds like your belts are squealing. open hood, have someone start it. watch and listen from the belt area. you may even see a pulley vibrate or wobble while its squealing. or the tentioner jumping around.
    then take the belts off and inspect the pulleys, you could have a bad idler, tentioner, water pump, alt, power steering pump or a/c compressor clutch. check all the pulleys for side to side play, make sure they spin smoothly.
    while the belts are off start the car to see if the noise is gone also. dont run it for to long with out belts, your water pumps not working and you'll over heat it. a few minutes is ok.
    or the belt could be just shot as well, while its off flip it over groves out and bend it over your finger, look for cracks and chunks missing, if so replace it.
  2. #2 Re: Loud Screeching Sound
    May 2012
    Burlington, Wisconsin
    I was told when I bought the car that the A/C was not working. Could the a/c compressor belt be the cause of that? I feel if that's it that could be making the sound.
  1. how can i make my car sound loud but good?
    By asite57 in forum General Tech Discussion
    Last Post: 04-28-2012, 01:58 PM
  2. loud as hell squealing sound from air vents
    By GTLGDP in forum General Tech Discussion
    Last Post: 12-13-2011, 05:45 PM
  3. Loud Metal Clanking sound
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2010, 02:05 PM
  4. Loud "Pop sound in rear 10 seconds after car is off
    By MidnightSpecial in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-10-2009, 07:00 AM
  5. New CV axle, Now loud screeching...
    By Greinerts in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2009, 12:58 AM
