Did you change the flex when you installed your speed daddy's?
Few things to check:
-Make sure the BBV- "Boost Bypass Valve" and and lines are working correctly
-Check to make sure you don't have a vacuum leak. What are your HGs?
-Did you change the flex when you installed your speed daddy's?
