Thread: The Newest Problem with no DTC...
Results 1 to 15 of 15
  1. #1 Re: The Newest Problem with no DTC...
    Apr 2009
    Fort Worth TX
    Shouldn't be going into lockup at 40mph? I believe and would have to check for this particular car etc, TCC lockup typically is programmed for around 35mph in third gear.
    I'd be more apt to believe this is tune up related. Please tell us brand of wires, brand and model of plugs, if you've checked the coil pack towers for corrosion and or cleaned the TB/airfilter recently.
    If you ever need to test if TCC has locked up. Keep your right foot steady on the throttle and gently press the brake with your left. You are aiming to turn on the brake light (pcm sees this) which unlocks the tcc and you should see a 200-500 jump in rpm. Letting off the brakes should allow it to relock.
    In drive the car should immediately unlock TCC at 40 mph under any acceleration, no? If just barely maintaining speed it shouldn't be "hunting" for lockup. This is when the PWM is working its hardest.
    I challenge you again Bill! -------- I'll probably lose again but that's OK.
    Watch, it's probably a vacuum leak, TPS or something stupid like that...DERP
  2. #2 Re: The Newest Problem with no DTC...
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    it's locking and unlocking fine.. i've checked a million times. i cleaned the MAF sensor and it's been running fine.. i took it on a 200+ mile trip.. the shuddering feeling happened once and didn't last long (which is strange).. it does seem to be more of an issue when the temperature outside is warmer.. next warm day i'll really test it.. so it's running absolutely fine but i doubt it's fixed... so i will re-post soon.
  1. Newest of the new guys
    By GTPWombat in forum Introductions/Noob Questions
    Last Post: 05-03-2011, 03:57 AM
  2. newest of newbies
    By dub shiesty in forum Introductions/Noob Questions
    Last Post: 07-06-2010, 06:12 PM
  3. Newest pics of my GTX!
    By basshead42 in forum Visual/Body Modifications
    Last Post: 07-20-2009, 08:09 PM
  4. Newest member
    By RMayer in forum Introductions/Noob Questions
    Last Post: 11-22-2008, 12:59 PM
  5. Newest 3800 Fan...
    By Deezul_AwT in forum Off Topic Discussion
    Last Post: 05-02-2008, 08:06 PM
