okay so once again, right before i take my car on a road trip.. i have a problem arising and no trouble codes to help me out. so let me TRY to describe this problem for you and perhaps you may know what it is that's causing it.
When driving the car generally 40+ mph while under slight load/acceleration I will feel the car and the gas pedal shimmering around a bit. If I take my foot off the gas it goes away instantly. While this problem is happening i see the RPM's drop 2 hundred or so then the RPM gauge will shake while back and forth a tiny bit while i am driving the car and giving it slight gas. It almost feels as though it's misfiring but the PCM is not picking up any misfires.
My three guesses are: Vacuum leak, dirty maf sensor, or the TPS sensor. Also over a month ago I had changed the plugs. The problem didn't start right after I changed them but a couple weeks after. I don't think it would be the plugs but I haven't ruled it out just because it's the most recent thing that was done to the car.
I'm going on a road trip in less than 24 hours and my car is the only option. Any possibly help you could give would be much appreciated. Thanks for thinking.
