Thread: Asstinace On Isel 10
Results 1 to 5 of 5
  1. #1 Asstinace On Isel 10
    SE Level Member Charged97's Avatar
    ATLANTA
    ok i got 2 ?'s for you folks i put a piece of card board under my car last night cause i suspect a lil oil leak it sat for 12 hours and this moring there was a dime size drop any thing i should worry about u think and i wonder were its coming from
    ? 2 anybody know a price range or problem my drive window has a new motor but towards the top it gets stuck (like the front piece of the glass gets stuck a lil ) and when i assit it a lil it goes up fine with a lil bit of help looked in it everything appears fine
  2. #2 Re: Asstinace On Isel 10
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    If its the size of a dime that should mean only a few drops which isn't that bad for a 12 hour time span. I would be concerned [because im kind of meticulous when it comes to keeping my car in working order] but i wouldn't be panicked. Just periodically check your oil level and make sure you aren't low.
    I know you said oil and i am assuming you mean engine oil, would i be correct in my assumption? We could help better if we were sure what kind of fluid it is and [more importantly] where its coming from.
    And i can't help you with the window problem i am not experienced in that area sorry.
    2006 Grand Prix GXP
  3. #3 Re: Asstinace On Isel 10
    ATLANTA
    yep its the motor oil the pontiac dealership said there was a lil seapge from the oil pan gasket how costly and hard is the oil pan seal to do
  4. #4 Re: Asstinace On Isel 10
    Oklahoma
    The oil pan is going to be one of the problematic things to replace. I have never tried it myself, but my understanding is that you have to loosen or lower the cradle/subframe some to get it out. There are a few on here that have replaced the gasket before, perhaps they will step in and let you know all the details.
  5. #5 Re: Asstinace On Isel 10
    TDCRacing
    Guest
    Quote Originally Posted by Charged97 View Post
    If and when you do this use a small bead of RTV along the pan gasket also. When replacing mine when the engine was out I didnt use rtv and now a have oil seepage also...And yes all bolts were torqed down to the proper ratings.
