So, you like Honda's?
Got it.
:D
Got it.
:D
I call BS. I think he recently changed his name to Sheff!
Need more Shelf.
Like the fact that it makes over twice the power compared to 99% of everyone here makes?
Ok, so does the CAI make a big differ in power compared to the WAI, or just a tiny differ?
No solid data was provided in this thread.
Thus no conclusion beside theory.
Theory says it can make a big difference.
Practice suggests once moving, IAT's will be negligible.
under 40 mph your IAT's will skyrocket.
above that, they'll be within 10-15* of ambient.
It will cost you power, but you won't use as much fuel granted you don't push the pedal harder to compensate.
I am Still kinda new and well what is IATs?
intake air temperature.
PCM will correct the timing based on it so its taken care of in a sense.
Unless you modify that table.
Also performance wise, did i gain or loose power from switch from the stock air box to the WAI?
So i dont really have to worry about the IAT if im leaving to stock other than the WAI?
Most likely a loss in power.
I think you are the only person that has told me that, i dont really think i lossed power though
