Way to go everyone, you pissed off the Sheff![]()
I'm here to learn, everybody, not make out with you!
wouldn the restriction of a FWI negate alot of the cooling affects?
I mean while cold air may be better, unrestricted warm air is for sure > more restricted cool air (to a certain extent obviously...)
Oh jeez Mike... that's a deep and dark cave you're wandering into.
A lot of people have it mixed up, and a lot of people simply don't get it.
The m90 is not 100% volumetrically efficient. It gets close under certain circumstances, however in the real world it is a way off from 100%.
Ask yourself this. Is the blower moving the same amount of air at a fixed blower speed on 5psi vs 10psi? If the amount of air is the same, then the inlet flow should be the same, right?
I went through this big time when I was explaining that under certain real world conditions the smaller TVS blower actually flows more air per revolution than the bigger, less efficient m90.
Oh I get that. I don't have a map in front of me but I can totally believe that a TVS or other similar setup would outflow it down low. The M90 is pretty "loose" and gets more efficient as RPMs go up until a certain point where heat starts to play a part and you go back down. Can we agree on that? :-)
You're confusing two different types of efficiency though. Volumetric Efficiency (VE) is how much air the blower is moving relative to its size. As the blower RPM goes up, the gaps that the air can sneak back out of become less pronounced and the unit becomes more efficient. But that just means that it's moving more air relative to the air it moves at lower RPM per rev. The boost usually increases in upper RPMs though because as the blower's VE goes up, the engine's VE goes down... this makes more boost. And more boost pushes back against the blower and lowers the blower's VE relative to how it would perform had the boost not gone up.
Thermal efficiency is an entirely different subject, but to put it into just a few words... boost = HOT. The m90 makes a LOT of heat, we all knew that, but I don't think many people understand just how much heat it makes, how different weather plays into that, and how different blower RPM and boost levels drastically change the delta temps.
Its all relative...
Although I would like to see the percent of people who have a filter directly on their throttle body compared to having a tube and a filter.
Pretty simply put.....It takes colder air longer to get hot.....Is it going to make a huge difference..No.....Will it make a difference no matter how small that difference is....yes
So, you like Honda's?
Got it.
Like the fact that it makes over twice the power compared to 99% of everyone here makes?
