Thread: 99 GTP Stalling, other weird stuff
Results 1 to 9 of 9
  1. #1 Re: 99 GTP Stalling, other weird stuff
    Hold up... let's discuss the diagnosis given, I'm not sure we should dismiss it so easily.
    What happens when the torque converter soleniod locks on? A code P0742 would indicate to me that the TCC isn't allowing itself to spin freely.
    How to tell: Well there's codes that don't turn on the check engine light. Therefore the car needs to be scanned. Most parts stores will do this for free. Have it checked out. Ask them for the actual code numbers that are currently stored. Likely...it's the one I mentioned. If so, then we can talk further.
    General stalling is one thing. However the rpm dipping as you stop is not a symptom of a crank sensor. Crank sensors allow the engine to stall at any given time. Slowing down means rpm is dropping and that's likely a very different issue.
    Read this to better understand the issue: http://www.sonnax.com/system/pdfs/12...pdf?1289926276
    Then read this to understand the stalling.
    http://www.fixya.com/cars/t4427790-d...tem_stuck_3_1l
  2. #2 Re: 99 GTP Stalling, other weird stuff
    May 2012
    Baltimore
    Ok so I talked to the tech that scanned my car and he said the scanner read: "torque converter switch lockup, transmission slipping." Sounds like I need a tranny? Or are there other things that could be causing this to happen? Also, I heard Lubegard can save your transmission, or buy it a little time. Thoughts?
  1. Stalling?
    By 98gtpzzp in forum General Tech Discussion
    Last Post: 11-24-2011, 04:01 AM
  2. Weird Electrical Stuff Tonight
    By FriboRage in forum General Tech Discussion
    Last Post: 04-04-2011, 03:08 PM
  3. stalling out
    By magician in forum Introductions/Noob Questions
    Last Post: 04-16-2010, 07:19 AM
  4. stalling
    By gnjim in forum General Tech Discussion
    Last Post: 01-04-2009, 11:47 AM
