Thread: GTP stalling and smoking.
Results 1 to 13 of 13
  1. #1 GTP stalling and smoking.
    SE Level Member spina74's Avatar
    blackwood
    My girlfriends car(2001 Gp GTP) has been stalling out constantly and I can't find the issue. When it stalls out it takes some time to start up and when it finally starts it dumps black smoke. So far I've replace the crank sensor which prolonged the time between stalling, but its since came back. So i replaced the TPS and MAF due to the codes being thrown after it stalling....again it prolonged the stalling but it came back. So i went over all the vacuum lines and replaced the cracked ones and then the car went several days without stalling, and now its back again. I'm at a loss on what to do. I checked the fuel pressure it has good pressure(43psi) and even when it stalls out the fuel pressure remains at 43.
    Disregard the posts below, I erased my old post and typed in the info above.
  2. #2 Re: GTP stalling and smoking and bad ebtcm
    people would need to know what you girlfriends car is,,year make and so on, first question, is the cel on? if so go get the car scanned if you have not yet.
  3. #3 Re: GTP stalling and smoking and bad ebtcm
    blackwood
    bump....
  4. #4 Re: GTP stalling and smoking and bad ebtcm
    I'm not familiar with the symptoms you have being caused by a bad EBTM It sounds more like a bad o2 or something else going on. With your HPT take a look to see if the O2 is toggling properly and or if there are any misfires.
    On the ebt/cm communication issue, I'd start by reseating the connector a couple of times to it.
  5. #5 Re: GTP stalling and smoking and bad ebtcm
    blackwood
    There was a old o2 sensor voltage code, a misfire code, and MAF code......but once i deleted them the only code that came back was the ebtcm code again....Im sure the misfire and o2 code was due to the stalling the running rich that often happens.
  6. #6 Re: GTP stalling and smoking and bad ebtcm
    I'm confused... what are symptoms of a bad ebtm? They aren't stalling and running rich to my knowledge. Those are symptoms of a bad maf and or O2 sensor.
  7. #7 Re: GTP stalling and smoking.
    blackwood
    bump....
  8. #8 Re: GTP stalling and smoking.
    how can you bump this?
    replace the sensor's throwing the codes.
    deleting the code does not fix anything.
  9. #9 Re: GTP stalling and smoking.
    blackwood
    easy, post the word bump so this post is "bumped" to the top of the list, and never did I say I simply deleted the codes I replaced the sensors that were causing codes to be thrown.
    How are we supposed to know you did that?
  11. #11 Re: GTP stalling and smoking.
    thats would be my next point as well.
    in that case check the wires for damage and the fuse boxes.
  12. #12 Re: GTP stalling and smoking.
    blackwood
    Quote Originally Posted by spina74 View Post
    Ill go over all the wires, any other suggestions incase they are in good shape?
    Very unorthidox method.
  1. Smoking is bad
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 09-12-2011, 07:57 PM
  2. Smoking in your car
    By Dobbs122 in forum Off Topic Discussion
    Last Post: 08-03-2011, 06:46 AM
  3. I'll have what he's smoking
    By gpgt04 in forum Off Topic Discussion
    Last Post: 08-11-2010, 01:12 AM
  4. Code p1573 after EBTCM replacement
    By xxmattfxx in forum General Tech Discussion
    Last Post: 09-18-2009, 08:52 PM
