Thread: Cleaning Coolant Tank
Results 1 to 13 of 13
BlackGT1 Cleaning Coolant Tank 05-03-2012, 05:13 PM
dsmuts Re: Cleaning Coolant Tank 05-03-2012, 05:14 PM
dazedandconfused I dumped a bunch if mean... 05-03-2012, 05:17 PM
coolone Re: Cleaning Coolant Tank 05-03-2012, 05:29 PM
04silverprix Re: Cleaning Coolant Tank 05-03-2012, 09:44 PM
BlackGT1 Re: Cleaning Coolant Tank 05-04-2012, 12:10 AM
99XC600 Re: Cleaning Coolant Tank 05-05-2012, 07:51 PM
FriboRage Re: Cleaning Coolant Tank 05-05-2012, 07:54 PM
BlackGT1 Re: Cleaning Coolant Tank 05-06-2012, 01:45 AM
Summit670 Re: Cleaning Coolant Tank 05-07-2012, 11:18 AM
BlackGT1 Re: Cleaning Coolant Tank 05-08-2012, 12:10 AM
Logan541 Re: Cleaning Coolant Tank 05-08-2012, 12:40 AM
dsmuts Re: Cleaning Coolant Tank 05-08-2012, 02:51 PM
  1. #1 Cleaning Coolant Tank
    SE Level Member BlackGT1's Avatar
    Sep 2011
    Fort Worth, Texas
    I'm doing a major cleaning of my car in a couple weekends. Trans fluid, filter, plugs, wires, fuel filter, oil pan and gasket, thermostat, and lastly a coolant flush and switch to Yellow Peak BUT, my coolant tank is dirty, like really bad. I cannot scrub the areas affected, so while I am doing the other work, is there anything, any solution, I could have the tank in to eat away at that dexcool gunk?
    2001 GT - Mods, Magnaflow Mufflers, K&N CAI
  2. #2 Re: Cleaning Coolant Tank
    bleach it clean
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    I dumped a bunch if mean green in it and shook it up and let it sit overnight and it helped but didn't clean it totally. Bleach might be the ticket
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  4. #4 Re: Cleaning Coolant Tank
    Nov 2011
    NY
    Took my tank off, a water hose flush the inside, soaked it in simple green after a brake cleaner scrub down, lol, looked like NEW.
    It looked new that is... until my axle started throwing greased, seems it'll need a new cleaning again soon.
  5. #5 Re: Cleaning Coolant Tank
    Bellevue, Neb. Close to Omaha
    Bought a new replacement tank for our '04 GP from the Chevy dealer today for $29. It was cheaper than a used one from one of the local wrecking yards.
  6. #6 Re: Cleaning Coolant Tank
    Sep 2011
    Fort Worth, Texas
    Some of the junkyards are ridiculously high.
    And i tried a hose and purple power. Not a lot better. But that was a while ago.
  7. #7 Re: Cleaning Coolant Tank
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    Cascade and hot water. Let it sit for about 30 minutes and rinse well.
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  8. #8 Re: Cleaning Coolant Tank
    Pennsylvania
    Dawn, very hot water, shake violently... rinse and repeat
    I did it in the bathtub though, so the nastiness would go down the drain and not into the ground... call me a tree hugging hippie but I dont want ethylene glycol or Dawn in my area's water supply or my soil.
    Sport Edition Kv5 18x8
  9. #9 Re: Cleaning Coolant Tank
    Sep 2011
    Fort Worth, Texas
    No I understand completely.
    Hopefully I can catch all my coolant as I drain it.
  10. #10 Re: Cleaning Coolant Tank
    Dec 2008
    Lincoln NE
    Take tank off, put your favorite cleaning solution in, and then put some small nuts and flat washers in so when you shake the tank around the nuts & washers will scrub away. If you're worred about getting all of them back out, count them before and after.
  11. #11 Re: Cleaning Coolant Tank
    Sep 2011
    Fort Worth, Texas
    Wow, that sounds perfect. I have plenty of nuts and washers to try that with.
  12. #12 Re: Cleaning Coolant Tank
    Feb 2010
    TN
    I did brake cleaner and let it soak the flushed with red hot water (boiled on the stove wear gloves so you don't burn your hands) Let dry reapeat.
  13. #13 Re: Cleaning Coolant Tank
    Hmm I've never had water turn red on me because it was so hot. Maybe it's a southern thing lol
  1. Coolant tank leak
    By nav in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2010, 12:05 AM
  2. Losing Coolant from Overflow tank
    By Suaveat69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2010, 10:00 PM
  3. Coolant recovery tank leak?
    By jagamite in forum General Tech Discussion
    Last Post: 12-01-2009, 03:40 AM
